As promised here are the photos of my system and I have identical systems apart from of them is built into a very slightly longer case.
It uses a 4 pin plug and socket for the connection of the iron handle and please note that I no longer use the standard handle as supplied with the system when purchased, although it does still work ok with it, I now use the T12-9501handle system as it provides better physical control over the tip, the standard handle has more of the tip exposed, otherwise they are same electrically.
I have confirmed that there is zero electrical connection between the DC supply and the Earth/GND connections using my DMM on continuity setting. As will see, I have provided a GND connection stud at the back of the enclosure to ensure that the enclosure is safely Earthed as the power supply is held in 2 rails on the bottom section and this does
not provide a very good GND connection to the enclosure, hence my modification. This has been reported to Quicko so that may no longer be the case as I have had mine for 16 months now so they may have modified the earthing.
