Author Topic: How to measure low inductance  (Read 4109 times)
Offline jarodtuftsTopic starter
« on: February 04, 2018, 12:27:36 am »
Help please.  I'm getting a bit frustrated trying to find an affordable LCR meter that will measure low inductance for a project that I'm working on.  I have to wind my own inductors so I want to test them before I install them.  They are in the range of 140nH to 3uH.  It seems that all affordable meters bottom out at 20uH (i.e. MASTECH MS5308 or IET DE-5000).  Any suggestions?
Offline David Hess
  • DavidH
Re: How to measure low inductance
« Reply #1 on: February 04, 2018, 12:31:14 pm »
The IET DE-5000 has a resolution of 0.001uH or 1nH on its 20uH range albeit with 2.5%+5 accuracy.  With kelvin clips and calibration, isn't that good enough?
« Reply #2 on: February 04, 2018, 06:35:45 pm »
That would be good enough.  Maybe I am misunderstanding the spec sheet.  When it says "Range 20.0uH / Resolution 0.001uH".  Does that mean "From 0 to 20uH", or does that mean "from 20uH to the next range"?
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #3 on: February 04, 2018, 07:48:12 pm »
I have a UNI-T UT612, this can do up to 100kHz test frequency and has 1nH resolution. This one is quite affordable and I am very satisfied with it.
We Are The Watt - Resistance Is Futile!
Offline David Hess
  • DavidH
« Reply #4 on: February 05, 2018, 03:37:25 pm »
It means a measurement from 0 to 20uH with a resolution of 0.001uH or 1nH.  The next range up is 0 to 200uH with a resolution of 0.01uH or 10nH.
« Reply #5 on: February 09, 2018, 02:06:49 am »
Thank you for clarifying that for me.  I purchased the MASTECH MS5308.  It is measuring my hand-made 3uH inductor very accurately.  in the nH range I'm getting readings that are close to what I expect, but the values move around quiet a bit.  I am suspecting my measurement method right now.  I'm going to try cutting the leads closer to the core.  I'm suspecting at the very low range that the lead length might be an issue.
Offline oldway
« Reply #6 on: February 10, 2018, 10:29:43 am »
As I measure small inductances that quite seldom, I use the parallel resonant circuit method.
I connect a precision capacitor of 100 or 470pf in parallel with the unknown inductance and I feed this resonant circuit with my high frequency generator through a 4k7 resistor.
I am looking for the resonance frequency (maximum voltage) and calculates the inductance .... the resonance frequency is known as well as the value of the capacitor, which allows to calculate the value of the inductance.
I use the probe X10 of my oscilloscope and I take into account the input capacity of my probe.
