I have a 141t mainframe. The manual was easy to find on Boat anchors website. My trouble begins with noise on the vertical display. Checking the supplies in the 141t I found the +248 to be low, so I fixed that. It was stuck at 210 volts. I checked all the transistors and the gain was OK pulling them out into a DVM with transistor testor. I did find an NPN that was open and replaced that. Still stuck at 210volts.
Staring at the schematic and measuring voltages, the adjustment never went low enough to turn on the regulator which pulls the low end of the transformer up to 70 volts, that sat at 5 volts. I spied R9 a 100K and bugged it, OPEN! Looking through my collection of resistors I found a metal film rated at 200volts 100K 0.1 watt and replaced the open resistor. Success! now the 248 will adjust.
Problem 2 there is an impulse noise on the -12.6volts. On a DVM it adjusts but the noise propogates to the vertical deflection.
Checking all the capacitors in the -12.6 they were all correct. Measuring the timing it was about 30KHz, Hmm maybe thats from the high voltage supply under the cover. There is a 5000uF capacitor across the transformer, and this regulator works by modulating one side of the transformer to acheive a steady -12.6, but its getting this impulse noise on it. There is a darlington formed by q9 and q4 but they are separated by the cable bundle and thus can pick up and amplify this stray impulse, it does not look like oscillation its induced.
I tried a 4.7uF ceramic 50v across the main rectifier capacitr C6 of the main frame. I may also put more capacitance on the -12.6 i f that doesnt work.
More work needed.....unless someone else has solved this. I think its design flaw as the parts on the board (c48, r46) were larger values then shown on the schematic.
