The alcohol you've picked is not fit for purpose! You need a bottle of pure (99%+) alcohol with a cork, not a spraying nozzle.
For solder, I'd recommend this one (I typically use 0. 5/8):
https://www.aliexpress.com/item/4000128472972.htmlIt's a very high quality solder, and 63/37 is better than 60/40 btw (no plastic phase, goes instantly from liquid to solid)
If you wanna try lead-free, this ones pretty good:
https://www.aliexpress.com/item/32824531083.htmlYou could use 0.6 for general purpose, and smaller diameters for SMDs.
For Flux, I highly recommend this one:
https://www.aliexpress.com/item/32394410435.htmlYou could easily apply it with either tweezers or wooden tooth picks, no need for syringes.
Also, I'd suggest you get a goot solder pump, as it's better then the average low quality ones:
https://www.aliexpress.com/item/32869114560.htmlFor wicks, I use these (2.5mm) and they work great:
https://www.aliexpress.com/item/32931554391.htmlFor cutters, I like these:
https://www.aliexpress.com/item/1005001736644112.htmlAnd this PCB stand is amazing:
https://www.aliexpress.com/item/4001126472525.htmlNothing wrong with a third hand (for smalker stuff, or connectors) but for actually holding decently sized boards, it's fantastic.
Never used a tip refresher, I don't see the point in getting one to be honest (just keep the tip's temperature in check, and don't leave the iron on execssively without need). Also, I'd highly recommend this lamp:
https://www.aliexpress.com/item/1005001593591937.htmlYou could just use it with a power bank (helps seeing what you're working on).
And as said above, there are also other things you should add to that list. Hot air station be useful (but if you're only getting started, it can wait I guess). Magnifier with LED lights is very useful, and a Microscope too (G1200 provides a pretty good cost/value ratio). Also, don't forget to get a stand for the iron (and better use a brass tip cleaner, not a sponge!)
