Author Topic: I now hate Ubiquiti - need a new bedfellow  (Read 6667 times)
Offline mapleLCTopic starter
« on: May 29, 2022, 01:41:43 pm »
As stated, I now hate Ubiquiti.
I have 7 perfectly operational wifi hot spots that I have owned for over a decade.  The investment, all told, was well over $1000, so over that time they cost me about $100 a year.
Again, perfectly serviceable, full bars on all devices.  Network mesh was working perfectly.
Enter the new Ubiquiti software?  Login data whore heaven.  Old gear?  Fuck you!  Network mesh is gone peon!  Don't move rooms!
So who makes good network gear that isn't a garbage pail like Ubiquiti is now?  I need a new bedfellow that isn't all feature block data whored up yet.
The following users thanked this post: Tom45, Geoff-AU
Offline madires
  • A qualified hobbyist ;)
Re: I now hate Ubiquiti - need a new bedfellow
« Reply #1 on: May 29, 2022, 02:23:03 pm »
Anything with proper hardware supported by OpenWrt.
The following users thanked this post: NiHaoMike, Whales, elecdonia, PKTKS, mapleLC
« Reply #2 on: May 29, 2022, 03:27:21 pm »
I dont know what that is, can you explain?
Offline madires
« Reply #3 on: May 29, 2022, 03:37:48 pm »
OpenWrt is an alternative open source firmware supporting many routers/APs (https://openwrt.org/). It's based on linux, runs quite stable and comes with tons of features. You can also install additional software.
The following users thanked this post: NiHaoMike, elecdonia, PKTKS, mapleLC
Offline AndyBeez
  • Country: cx
« Reply #4 on: May 29, 2022, 05:11:47 pm »
If you're on a small budget, I hear good things about TP Link's Omada range. It's not Cisco/Meraki, but it's not priced like Cisco! It's both cloud based or stand alone configuration. Check out: https://www.tp-link.com/uk/omada-sdn/
You cannot make a good landing out of a bad approach. Except in wind shear.
« Reply #5 on: May 29, 2022, 06:03:25 pm »
That's what Ubiquiti "was" also.  Now it's even a standalone data whore. I am hesitant to repeat the behavior that led me to Ubiquiti, but if it supports true standalone, then I would consider it.
This Merkai is cloud based data whore, so that's not an option.
I wonder if I just need to buy old gear like I do with printers.  I have a few workhorse HPs pre-page count obsolescence whoring started, the 3 together should satisfy my lifetime need for printers.  Not enough people sit down and really calculate what these companies actually cost them like I did with Ubiquiti.  Now they want to hose me so I can start paying again just when my cost of operation has dropped below $100 a year?  No thanks.  Find other goobers to buy your junk.
« Reply #6 on: May 29, 2022, 06:07:51 pm »
https://news.ycombinator.com/item?id=21432138
Ubiquiti became aware of this and has blocked it in it's firmware, what a shocker.
Offline ygi
« Reply #7 on: May 29, 2022, 08:40:07 pm »
Often times Openwrt's initial installation is possible through some security exploit either in the firmware or its bootloader. Maybe Ubiquiti simply did their job by patching that security flaw without malice. Yeah I know... wishful thinking and all that.
Offline Whales
    • Halestrom
« Reply #9 on: May 29, 2022, 11:27:47 pm »
+1 for OpenWRT supported hardware.  Devices last longer with OpenWRT, or at least you can tolerate them a lot longer
Problems that OpenWRT has allowed me to get around:
 - Bad guest wifi implementations that randomly block all packets (Unfi AP ACs)
 - Bad guest wifi implementations that don't actually block access to other devices on the LAN (ie not really a guest mode at all, just a second SSID)
 - No guest wifi implementations
 - Requiring reboots every few days to weeks for wifi chipset stability (sadly in one case I did this via scheduled down/up, brrr)
 - Bad/old VPN software
 - Bad/old VPN software getting disabled by 1st-party vendor in updates because they realise it's so bad/old (TP-link)
 - Cloud-connected firmware (ie any feature beyond fetching firmware updates)
 - EDIT: Bufferbloat (internet slowing to a crawl and dropping packets when someone uses lots of upload bandwidth or torrents)
 - EDIT: NAT table exhaustion (again torrent users.  Modify the lifetime of stale NAT entries)
 - Probably more that I can't remember.
There are first-party OpenWRT devices sold by companies like GLinet, otherwise popular supported platforms like some (check version codes!) of the TP-link archer series are extremely well supported for Wifi.  It's been a while since I looked.
« Last Edit: May 29, 2022, 11:35:04 pm by Whales »
« Reply #10 on: May 30, 2022, 12:47:59 am »
Would this be an example of such a product?  Router aside, could I use these to more or less replace the ubiquiti wireless setup I have?
https://store.gl-inet.com/collections/smart-home-gateway-mesh-router/products/velica-gl-b2200?variant=32131378184286
Offline Whales
    • Halestrom
« Reply #11 on: May 30, 2022, 01:11:31 am »
Potentially.  There are lots of variables.  I have not bought a GLinet device in many years (and even then it was a fleet of a few dozen of their lower-end models), so I can't pass much judgement.
I recommend reading the OpenWRT wiki page for a device before you buy it.  Sometimes there are gotchas.  It also lets you find out what wireless chipset it uses, letting you check wifi features (eg how many MIMO channels) and find out if there are competitor's units with the same wireless chipset but at a much lower price (ie basically identical units just in different clothing).
GLinet offers some Wifi APs that can support PoE if that's your thing.  I like PoE powerable units (I won a PoE switch at an event and now use it at home) but not everyone wants to pay the premium for these features.
Question: What is the current Ubiquiti hardware that you're angry with and wanting to replace?  OpenWRT might already support it.  I didn't have any issues flashing OpenWRT onto any of the AP AC lites I've bought first party (for work) or second hand (for home).
« Reply #12 on: May 30, 2022, 02:25:55 am »
I have a set of the Unifi AP units and whatever they called the previous version.  I read it is possible but you have to back out to an old firmware because the newer ones block the flash by openwrt - it just sounds like one of those things that is fraught with failure and frustration.
Offline madires
« Reply #13 on: May 30, 2022, 01:26:06 pm »
Didn't know GL.iNet before. They have some interesting devices with a great price-performance ratio, similar to TP-Link. RAM and Flash sizes are also reasonable. I'll keep an eye on them. Thanks for the hint!
« Reply #14 on: May 30, 2022, 04:06:47 pm »
It does indeed look interesting, I may try it and report back here, though it might be a while to get enough inertia going to re-learn all this stuff.
Offline NiHaoMike
    • Facebook Page
« Reply #15 on: May 30, 2022, 05:30:10 pm »
Mikrotik appears to be a direct competitor to Ubiquiti.
Offline Whales
    • Halestrom
« Reply #16 on: June 06, 2022, 07:42:04 am »
BUMP
Just got my hands on a second-hand GL-inet GL-B1330 "Convexa B" wireless access point for $50AUD.  Flashing the latest openwrt firmware took a few minutes (the thing already runs OpenWRT, so it's dead easy) and it's now running a duplicate config of my other Unifi AP AC Lite wireless access point (same SSID + psks, so devices should transparently roam between them).
I'll update here to tell you how well it performs after a few days of usage.
The following users thanked this post: mapleLC
« Reply #17 on: June 06, 2022, 08:30:45 am »
Is that a wireless access point or a router?  The links points to a router.
Offline Whales
    • Halestrom
« Reply #18 on: June 06, 2022, 08:54:49 am »
It's both, either one or neither.   It's a generic device that you configure to be anything that you want.
Internally it's an ARM SoC running Linux, an ethernet switch connected to 3 RJ-45 ports + the SoC and a wireless chipset.  As far as I'm aware all WAPs and routers on the market today (<$500 or so) are this same basic structure, just with some features not implemented or artificially restricted in firmware.  The OpenWRT firmware lets you do whatever you want from the simple to the insane.
To make it a dumb WAP I just disabled the DHCP server on the LAN interface group and told it to behave like a client instead (DHCP for its own ip), then setup passwords and wireless configuration as per normal.  OpenWRT comes by default with the wireless interfaces and LAN ethernet interfaces already bridged, so you don't have to change anything there.  I used the web interface to change these settings, but you can also ssh/telnet in if that's your thing.
« Last Edit: June 06, 2022, 10:22:31 am by Whales »
Offline ygi
« Reply #19 on: June 06, 2022, 01:00:34 pm »
BUMP
That's technically not roaming, that's losing connection then reconnecting to the strongest signal with a new session. True seamless roaming needs centralized authentication or some peer to peer exchange between APs. Typically that's done through 801.1x (the most complex way with a dedicated server) or 802.11r where APs participating to the same domain constantly exchange clients authentication infos. Though many mainstream client devices don't handle advanced config properly or at all due to poor wifi driver.
The following users thanked this post: SteveyG, mapleLC
« Reply #20 on: June 06, 2022, 02:52:22 pm »
Can you expand on "technically"?
Is it like 60hz frame rate which technically is 60 frames a sec but you see it as contiguous?  Or here, will you see the bars disappear and reappear again quickly?  Thats disruptive. The problem with my current setup is that its never thinking about finding a closer hotspot, it just follows the one weakening across the house until it resets (how I dont know - seems like the phone is doing it not the wifi).
Offline Whales
    • Halestrom
« Reply #21 on: June 06, 2022, 10:49:38 pm »
Yes it's not 802.11r transitions, I'm too lazy to set that up.  I've heard the term "roaming" used in both reference to that standard and in terms of moving between WAPs with the same SSID+psk.
I believe this behaviour is up to the client, unless the WAPs force their hand by forcing a disconnect (or something similar).
My wireless config in OpenWRT has some options that might (?) be useful here: "force disconnect on low ACK" and some distance-tuning variables like max distance to clients (I need to read into this one, maybe it forces disconnects once you are out of range?).  There has probably been some thought put into this, I have not read deeply into it.
Some people refuse to use the same SSID for both their 2.4GHz and 5GHz access points because many devices are too stupid to select between them well (keep in mind both the 2.4Ghz and 5GHz networks are broadcast by the same physical WAP).  I don't bother, things work OK for me on that front.
Offline Whales
    • Halestrom
« Reply #22 on: June 06, 2022, 11:31:30 pm »
Some possibly relevant reading:
[...] Clients should always roam before they get anywhere near the low data rates we’re proposing to disable. For example, iOS devices (v8 and later) trigger roam scanning at -70dBm and roam when there is an 8-12dB difference between the current and new APs.
Sticky Clients \ Roaming
Sticky clients just suck. If a client device has poor SNR (either unidirectional or bi-directional), it will use unsophisticated modulation, and so will use low MCS/data rates. Equally bad, sticky clients significantly extend the interference range of a BSS, and CCI drives down network capacity. By raising the MBR to 12M, it limits the data rate that the AP can use for transmissions.
Poor client drivers are partially to blame for stickiness, and poor network design is the rest of the story. Good enterprise design often means use of fairly low AP power to prevent CCI. (Before you WiFi nerds start throwing out corner cases, I used the word “often” on purpose.) Turning the AP power down means that clients won’t be able to hear the AP as far, and so will be forced to roam sooner.
The author claims you should disable some of the lower speed legacy wifi rates and reduce your wireless APs' transmit power in order to get your clients to more reliably roam between APs.
« Last Edit: June 06, 2022, 11:45:54 pm by Whales »
Offline ygi
« Reply #23 on: June 07, 2022, 10:30:15 am »
Whales pretty much said it all already. The difference would be, say you're downloading a file and you "roam" between independent APs, well your download gets interrupted. It's effectively a disconnection due to bad connection. Because the wifi disconnection is caused by poor reception, AP will waste time trying to resend data to the now out of reach client thus triggering a session termination further up the line due to timeout and/or management messages. If all stars align, you can trigger a client side disconnection and full reconnection before a session timeout but that's assuming you have a very dense AP coverage to do it fast enough. Better than nothing anyway but you don't have any control over it if we're talking about smartphones and the likes.
Whereas with true roaming, your client wireless session (referring here to its valid authentication to a trusted AP) is handed over to the next trusted AP in the same domain without restarting the time consuming authentication process or wasting bandwidth resending data to nowhere. With the added benefit of not reducing modulation speed for all other clients connected to the same AP.
To achieve that, either APs need to trust each others and exchange their session info or they just delegate the whole authentication/session tracking process to a dedicated server. Then again, bad client drivers will give you headaches no matter what.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #24 on: June 07, 2022, 11:56:30 am »
Mikrotik offers cheap hardware with very versatile software, at a learning curve. They're definetely not intended for end-user sales, which you can do with ubnt. But in the business realm they compete.
Though, mikrotik is a generation behind on 802.11 iirc.
