Author Topic: Identifying the MCU from RT85 handheld Radio  (Read 1687 times)
Offline Cassus
« on: June 11, 2021, 03:36:29 pm »
Hello,
I am trying to reverse engineer a RT85 Retevis handheld radio in order to produce a custom firmware. The main problem I have is to figure out the microcontroller they are using. They went through the effort of grinding the top of the chip to make it harder for people to guess what it is.
The remains of a logo is still distinguishable on the bottom of the chip. Does anyone recognize a brand logo? I doubt it is an obscure Chinese manufacturer otherwise they would have tried to mask it.
Also, the programming port has only 4 pins so I guess VDD, VSS, Data and Reset. That already excludes some brands like Microchip which uses at least 5 pins.
I have access to a J-Link, ST-Link, ICD3, Oscilloscope and Logic Analyzer if that can help.
here are the pictures:
BTW, The TH-UV88 handheld radio from TYT uses the same PCB and doesn't erase the markings so if anyone has one lying around...
Offline geggi1
Re: Identifying the MCU from RT85 handheld Radio
« Reply #1 on: June 11, 2021, 08:08:18 pm »
I guess this is a game of elimination.
Start finding possible candidates for MCU same packages is a good start.
Reverse engineer the circuit around the MCU to find pins that are detectable like power, gnd, databusses for cummunication to other devices and programming of the radio.
Do the elimination by checking datasheets for the possible candidates.
Offline Cassus
« Reply #2 on: June 12, 2021, 08:08:59 am »
the problem with the package is that there is an insane number of different MCU when you dig a little. There are the common brands like Microchip, Atmel and STM but tons of small ones too. that's like finding a needle in a hailstack.
+ the remains of the logo kinda looks familiar so that's even more frustrating
Offline Cassus
« Reply #3 on: June 12, 2021, 09:25:58 am »
I think I found the logo. it is similar to the one from another chip on the PCB. that make sense that they would use chips from the same manufacturer.
can't find any infos on any QFP 48 chip on Beken's website though
« Last Edit: June 12, 2021, 09:33:12 am by Cassus »
Offline amyk
« Reply #4 on: June 14, 2021, 01:25:30 pm »
That's because it's a QFN32...
http://antena.fe.uni-lj.si/literatura/Razno/BK4815/BK4815N_Datasheet_v1.0.1.pdf
But Beken don't make MCUs. I'd say the erased logo looks more like Silabs or Cypress.
Offline EOZ
« Reply #5 on: June 18, 2021, 04:16:56 pm »
It is a SC95F7617 from SinOne. A 8051 based microcontroller.
I have been trying to find the 32-bit block cipher used in the firmware with no success yet. Microcontroller is read protected, so no clean firmware reading is possible.
Good luck!
Offline DavidAlfa
Hantek DSO2x1x            Drive        FAQ
Stm32 Soldering FW      Forum      Github
Offline andynvkz
  • Country: ru
« Reply #7 on: June 22, 2021, 02:50:17 pm »
Good luck!
TEA 32bit block 64bit key
https://vrtp.ru/index.php?showtopic=32228&st=0 - the most up-to-date information
« Last Edit: June 22, 2021, 03:14:52 pm by andynvkz »
Offline EOZ
« Reply #8 on: June 26, 2021, 10:58:19 pm »
Thank you for the info but I need some proof or at least a good clue before putting a computer to break the key, because It can be TEA, but it can be also Skip32, SkipJack, SPECK, RC5, or any other of the hundreds 32-bit block ciphers available out there.
Unfortunately I have only a few pairs plain text <--> cipher text so it is impossible to make any analysis to guess the cipher used.
Offline andynvkz
  • Country: ru
« Reply #9 on: June 29, 2021, 11:06:25 pm »
Forgot about keeloq, in fact, there are not so many algorithms suitable for this processor, I also wondered, but the documentation on SC contains descriptions of a bootloader working via UART with encryption, I asked SinOne for this information, they sent me the source codes of the bootloader and ready utilities for working with it, and lo and behold ... TEA is used there, I'm 90% sure that TYT did not change anything
Offline EOZ
« Reply #10 on: July 05, 2021, 03:53:28 pm »
Interesting... I have the SinOne bootloader tool, documentation and source codes but no encryption in any of these bootloaders or documents.
It would be nice to have a look to the source code of a bootloader supporting encryption.
Offline andynvkz
  • Country: ru
Offline EOZ
« Reply #12 on: July 09, 2021, 07:44:55 pm »
Thank you!
You were right. They didn't modify a single bit of the TEA32 algorithm.
Time to crunch some keys.
« Last Edit: July 10, 2021, 07:06:45 pm by EOZ »
Offline EOZ
« Reply #13 on: August 17, 2021, 09:42:31 pm »
Hello. Just a quick message to show the progress in finding the encryption key used for the RT85 firmware.
Cypher Used
A quick look at the firmware files shows the cipher is some kind of block cipher with a 32-bit block size. Thanks to andynvkz, who was able to get a Bootloader Toolkit from SinONE (the microcontroller manufacturer) we can confirm the cipher used is TEA, the Tiny Encryption Algorithm, in the 32-bit block size / 64-bit key version.
You can find a working code of the algorithm used at:
https://github.com/0x000000AC/Tiny-Encryption-Algorithm/blob/master/tea16.c
Interesting to note the Bootloader Toolkit includes a tea library for the Keil compiler to be used with your bootloader. This means it is very probable the firmware was compiled also with the Keil 8051 C Compiler.
Endianness
The endianness used is the native one from the 8051 microcontroller. Let's call a the byte at address n, b the byte at address n+1, c the byte at address n+2 and d the byte at address n+3. These four bytes creates the 32-bit word ( a << 24 ) | ( b<<16 ) | ( c << 8 ) | d
Because the TEA algorithm divides the 32-bit word into two 16-bit chunks, we have V0 = ( a << 8 ) | b , and V1 = ( c << 8 ) | d
Cleartext / ciphertext pairs
If you are not familiarized with the 8051 microcontroller this is the most difficult part to understand. Getting pairs of cleartext / ciphertext was the most difficult part, because the entire firmware files are encrypted, but because it is code for a 8051 microcontroller, some information can be extracted from the first bytes, where the interrupt vector table resides. For example, these are the first bytes from one firmware file:
file: A_UV88V1_09_20190929.bin
00000000: d298fb36 e1628796 f8ce2d23 d389995d  ...6.b....-#...]
00000010: e1628796 e1628796 f8ce2d23 5c8948c3  .b...b....-#\.H.
00000020: f8ce2d23 94f7c212 e1628796 e1628796  ..-#.....b...b..
00000030: e1628796 e1628796 e1628796 e1628796  .b...b...b...b..
The first 8051 interrupt vectors are:
Address   Interrupt
0x0000    Reset
0x0003    INT0
0x000B    Timer 0
0x0013    INT1
0x001B    Timer1
0x0023    Serial
The Reset vector is located at address 0x0000. Almost every 8051 compiler places a LJMP instruction there pointing to the start of the code, so we know the first byte is 0x02, the LJMP opcode, followed by the jump address (two bytes).
The next interrupt vector (INT0) is located at address 0x0003, and virtually any 8051 compiler places there a LJMP instruction (0x02) followed by the jump address in every used interrupt vector. In this case this will take bytes at address 0x0003, 0x0004 and 0x0005. The same for all the other interrupts: a LJMP opcode followed by the jump address.
There are 8 bytes between interrupt vector addresses, and only three bytes are used (LJMP + address). The unused bytes usually are filled with zeros and we know the Keil compiler fills all these unused bytes with zeros. We also see for addresses over 0x0028 the same 32-bit sequence is repeated over and over: 0xE1628796. It is simple to deduce this is the encrypted version of 0x00000000.
Now let's see the addresses 0x000B (Timer0), 0x001B (Timer1) and 0x0023 (serial) They all are inside a 32-bit block with value 0xF8CE2D23 and all of them correspond to the "23" part of it. All these blocks are followed by no zero blocks, this means they are used interruptions vectors, so we can asume they contain a LJMP as last byte. And analyzing the bytes before it, it is easy to see they are zero filled bytes.
With all this information we can "partially decode" the first bytes of the firmware:
00000000: 02xxxx00 00000000 00000002 xxxx0000
00000010: 00000000 00000000 00000002 xxxx0000
00000020: 00000002 xxxx0000 00000000 00000000
00000030: 00000000 00000000 00000000 00000000
So we can get the following correspondences:
E1628796 ---> 00000000
F8CE2D23 ---> 00000002
And the following partial correspondences:
D298FB36 ---> 02xxxx00
D389995D ---> xxxx0000
94F7C212 ---> xxxx0000
If you analyze some firmware files you will find many partial correspondences, but unfortunately only these two full ones.
In few words: the goal is to find a 64 bit key that translates 0xE1628796 into 0x00000000 and 0xF8CE2D23 into 0x00000002.
Breaking TEA
This is the funniest part. A simple web search and you will find some people saying a 32-bit block cipher is insecure or even that TEA is broken. Well... it is obvious they have never tried to break a real world TEA cipher.
Some even dare to publish papers and code that are supposedly capable of breaking TEA but when you read it you discover they are breaking a one round TEA version (something that is trivial to break). The real TEA uses 32 rounds: they are trying to demonstrate how to open a safe breaking a cardbox shoe box.
Some "serious" papers describe a method to guess the key that requires the key (!). This is the case of a description about related key attack on TEA that requires to cipher a number of cleartexts under the unknown key (how? It is unknown) and a related key, constructed using some math to the original key (how? it is unknown). Then comparing both ciphertexts they affirm the original key can be deduced. The problem is you need the original key to cipher some plaintexts, and also you need it to created the related key. If you have the original key, what is the point?
An interesting paper talks about the relationship between the bitsum of the key and the bitsum of the chiper text under certain keys with a defined pattern. The bitsum of a binary number is just the number of ones in its binary representation. I made a lot of tests and I can't see this bitsum relation using "normal real world keys"
My findings: The only property of TEA I have tested and confirmed is the equivalent key problem, which reduces the keyspace from 2^64 to 2^62 keys. It is a nice reduction, but not enough.
It is really easy to find a key that decodes E1628796 into 00000000. With a 32-bit block size and 64-bit key a first guess is there must be about 2^32 keys that decodes E1628796 into 00000000 but hopefully there must be only ONE (four) that decodes E1628796 into 00000000 *AND* F8CE2D23 into 00000002. Only one, but because of the equivalent key disadvantage of TEA, there are four equivalent ones.
To check this premise I used a version of TEA using 16-bit blocks and 32-bits keys and encoded 0000 and 0002 under a random 32-bit key. Then I tried all possible 32-bit keys (a few seconds under a modern CPU) and got a little bit over 2^16 keys that decoded into 0000 and only four (all of them equivalent) that decoded both values into 0000 and 0002. The numbers seems to hold.
As today, I have nearly 150000 keys that decodes E1628796 into 00000000, for example
[0064B606046603F0] - 00000000 - 992C0C2D
[04EF5C0C4B8A75A6] - 00000000 - 5D4A3022
[0E8D27E935CCC071] - 00000000 - C92F088D
[1491C6DF16B59162] - 00000000 - 9F5B9947
[17D3D83E1D93A685] - 00000000 - C9FDAC48
[17F81BC445CB28D2] - 00000000 - 8D629136
[38745F2A5F977378] - 00000000 - BBE93F6C
[48BE1F274F7248A5] - 00000000 - 2D7245B7
[48ED01B045A21972] - 00000000 - 0FA130C1
[4D38672B39CF522C] - 00000000 - D3FEA581
[59FE42152BAD1DF3] - 00000000 - DF51694F
[650200426E037BA9] - 00000000 - 8C775878
[6631656D23F90172] - 00000000 - AC5D320F
[6F27895A728A6299] - 00000000 - 64397638
[770B11DC0B13CD0B] - 00000000 - E603E976
First column is the key in order K0:K1:K2:K3. Second column is the decoding of E1628796, and third column is the decoding of F8CE2D23. You can use these values as test vectors. The "best" matches I have found yet are:
[4EB3C5686AC86E10] - 00000000 - 0000D7E2
[63B710B5194C7EF3] - 00000000 - 000088F3
[5D0816A177F3A33E] - 00000000 - A10C0002
And, if bitsum is a thing with real world TEA, this one is also interesting:
[00E20E084977C31D] - 00000000 - 11804000
Although promising, they can't be used as a starting point to find the real key because the smallest change in the key and everything in the output changes a lot. TEA is a really powerful random number generator.
Any idea? Any expert in cryptography out there? Any clue or algorithm to reduce the search space way down from 2^64 (2^62)?
I started using the CPUs, and later, motivated by andynvkz I switched to GPU but still my worst case scenario is a bit over 500 years. Just too much  :-DD
Any idea will be welcomed.
andynvkz: I wrote you but your inbox is full, so I got the messages back.
Offline andynvkz
  • Country: ru
« Reply #14 on: August 24, 2021, 01:09:19 pm »
hello, what video card are you using for the password? a couple of days ago I bought a Geforce RTX3080Ti, but I'm thinking of rewriting the program from OpenCL to Cuda, like Cuda 30% faster
Offline EOZ
« Reply #15 on: August 25, 2021, 06:21:41 pm »
I'm using the internal GPU in the Intel processor. A toy GPU, but nearly 70 times faster than  a single CPU core. Not bad at all :-)
I had the opportunity to make a quick test on a RTX2070 and whoa!, it is fast! but not enough. The worst case scenario is still around 15 years.
I'm wondering if a FPGA or an small number of them would be a better approach.
Offline andynvkz
  • Country: ru
« Reply #16 on: August 26, 2021, 04:48:03 am »
I bought myself an rtx3080ti, if you have a ready-made bruteforce program, would you like to share it? since I don't have much time to study cuda yet
Offline amyk
« Reply #17 on: August 27, 2021, 01:52:45 am »
Try power glitching or other side-channel attacks. That's probably going to be easier than bruteforcing a key. (Do we know what else could contain the key, besides the MCU itself?)
Offline andynvkz
  • Country: ru
« Reply #18 on: August 30, 2021, 01:46:36 am »
hello, there is no password in the firmware for the firmware, it is only in the MCU-LDROM, or hack the TYT server, then maybe we will get the firmware source)))
Offline EOZ
« Reply #19 on: August 30, 2021, 12:21:40 pm »
Yes... the key is in the LDROM (bootloader), but of course it is read protected.
Glitching or sidechannel attacks? It would be nice but I have no experience in that and the manufacturer's datasheet say it is resistant to glitching attacks: "The SC95F751X has very excellent anti-jamming performance". If it is true, it will not be easy.
I'm going to try the FPGA route. It is a good excuse to play with them.
