Author Topic: Ikea VINDRIKTNING Air Quality Sensor  (Read 1631 times)
Offline calliTopic starter
  • 3D Blender and Maker
    • Blender Buch
« on: July 14, 2021, 06:06:06 pm »
So I got one.
My post at twitter: https://twitter.com/blenderbuch/status/1414614797602205703?s=20
USB-C but only for power :)
Nothing at the Fan_PWM. Some Eastsoft MCU, thats one of the 3ct ones?
Can't read the exact type.
I really did expect more info, this device is not that new?!
Cheers,
Carsten
Carsten Wartmann: Make Magazin DE - Autor - Dozent - 3D - Grafik - Maker
http://blenderbuch.de/
Offline DrG
Re: Ikea VINDRIKTNING Air Quality Sensor
« Reply #1 on: July 14, 2021, 06:19:17 pm »
Looks like a Cubic particle sensor (Chinese) - maybe this one https://www.directindustry.com/prod/cubic-sensor-instrument-co-ltd/product-54752-2240279.html
Get it clearly identified (there are markings somewhere, like around that bar code. Find a data sheet, get the protocol (likely old-fashion serial or maybe I2C) and then the supporting cast will make more sense. That's what I think anyways.
Hope it helps
- Invest in science - it pays big dividends. -
Offline thm_w
  • Non-expert
« Reply #2 on: July 14, 2021, 09:31:51 pm »
All that for $12? that is incredible.
Its hard to just find a laser PM sensor alone for $12.
But yeah if you can get the serial data output (most of these use normal serial protocol), then it would be much more useful, get it displayed on a small LCD. You can scope whatever the onboard micro is doing if a request packet is needed.
Offline DrG
« Reply #3 on: July 14, 2021, 09:55:45 pm »
You can get older ones fairly cheaply - e.g., http://www.diymore.cc/collections/new-product/products/dsm501a-dust-sensor-pm2-5-detection-dector-allergic-smoke-particles-sensor-module-for-air-cleaner-air-condition-for-arduino?_pos=1&_sid=bd444598f&_ss=r
Now, evaluating how good they are is another matter.
Offline DrG
« Reply #4 on: July 14, 2021, 09:58:26 pm »
So I got one.
Cheers,
Carsten
If it is a PM1006K, you can see the specs here https://pdf.directindustry.com/pdf/cubic-sensor-instrument-co-ltd/pm1006k-led-particle-sensor-module/54752-927719.html
A 5V device and straight no-frills serial except that TX and PWM are shared. I would need to read for a while to understand that completely - I guess you just abandon the PWM for the short amount of time that it takes to send a read request and then go back to whatever duty cycle you are using?. Are you certain that yours has a fan that you can see or hear?
« Last Edit: July 14, 2021, 10:03:07 pm by DrG »
Offline thm_w
  • Non-expert
« Reply #5 on: July 14, 2021, 10:55:26 pm »
They call it laser but it looks like a typical cheap crappy LED based sensor. and I don't think it will differentiate particle size.
The dust sensor module DSM501A is low cost, compact size for a particle density sensor. It is used to quantitative particle (> 1 micron) measurement with the principle of particle counter,
Offline DrG
« Reply #6 on: July 14, 2021, 11:12:58 pm »
I think the 501 (and presumably the 501A) uses an IR LED see https://www.atlantis-press.com/article/125910167.pdf
Offline aix
« Reply #7 on: July 24, 2021, 09:08:52 am »
Looks like someone's put together ESP8266 firmware with MQTT publishing:
https://github.com/Hypfer/esp8266-vindriktning-particle-sensor
The following users thanked this post: calli
