Author Topic: Is it possible for a soldering station to kill tips  (Read 789 times)
Offline Ebyte64Topic starter
« on: March 21, 2024, 05:10:41 pm »
Good day, everyone. I am a new user with a =n interest in electronics and repair.
My question is, is it possible for a soldering station to kill soldering tips?
I have two stations. Both cheap ones using the C210 cartriges. I will link them below.
One of them is a Sunshine S210.
https://www.sunshinerepairtools.com/SUNSHINE-S210-Smart-Portable-Soldering-Iron-p4384457.html
The other is a GVM T210S.
https://www.exinxun.com/rework-station/gvm-t210s.html
The two companies, GVM and Sunshine seem to be the smae.
So the sunshine one has worked perfectly with the same C210-k type cartrige from the same company for two months now.
But the GVM has had two cartriges fail while using it for two weeks. One was the GVM C210-K cartrige that comes with it and the other a Sunshine branded C210-IS cartrige.
Both cartriges heating elements just seem to burn out. So is it at all possibe the GVM might be at fault or just luck of the draw because I am usding cheap knockoffs and not true JBC ones?
Any feedback will be apreciated.
Offline ndarjo21
  • Country: id
Re: Is it possible for a soldering station to kill tips
« Reply #1 on: March 21, 2024, 07:49:31 pm »
the voltage too high perhaps. just check it
Offline thm_w
  • Non-expert
« Reply #2 on: March 21, 2024, 09:13:38 pm »
GVM page states: 120W peak power, rapid heating, 2 seconds tin melting, no difficulty in soldering joints of different sizes.
Sunshine page states: 110W peak power
The sunshine AC adapter is tiny, so I guess its not anywhere near 110W.
The "official" spec from JBC T210 I can find says 20W, but the station is claimed 40W, so probably around 40-50W is what it really should be using peak.
If you have a meter to measure power from the wall you can get an idea of how much these stations are overdriving the tip. 120W could cause it to burn out quickly.
« Reply #3 on: March 22, 2024, 08:54:44 pm »
Thank you very much for your feedback. I apreciate it.
Offline shabaz
« Reply #4 on: March 22, 2024, 09:09:14 pm »
For what it's worth, KSGER C210 Portable is nice, compared to some of the other C210 iron clones.
I've tried a few others, and that one was the only one I found to be really usable, powered from a 12VDC supply such as a bench supply, with 0V connected to ground (i.e. _not_ using any supplied ungrounded DC adapter). The current draw in normal use will be a few hundred mA, but will peak at several amps, especially when touched to a large ground plane, etc.
I can't comment on reliability, since I've only used it for a few months. I don't expect it to be anywhere near as reliable as a decent brand bench iron of course. These cheaper portable irons are maybe best considered as throwaway items after a few of years use (if lucky).
Offline thm_w
  • Non-expert
« Reply #5 on: March 22, 2024, 10:07:40 pm »
Yes I use the ksger and it works well. If I remember its around 40W at 12V, then if you want to overdrive it you can bump up to 21 or 24V. Supposedly it self limits the power but I don't know how well that works (I posted here somewhere I think).
Its not an all-in-one station but its definitely killer value at $24.
The following users thanked this post: shabaz
