Author Topic: Jabe UD-1200 vs. Jabe UD-1200 PRO vs. JBC CD-2SQE - need Firmware for UD-1200  (Read 49988 times)
Offline balu.2019@gmail.com
  • Country: in
Re: Jabe UD-1200 vs. Jabe UD-1200 PRO vs. JBC CD-2SQE - need Firmware for UD-1200
« Reply #100 on: February 21, 2024, 10:45:02 am »
I am able to get the bin file for F103, can i use same for STM32F2 series as well
Thanks & Regards,
Bala
Offline JimKnopfTopic starter
« Reply #101 on: February 21, 2024, 11:07:16 am »
@balu.2019@gmail.com Please respect the forum rules and create a new topic in microcontroller section.
After a while, i reviewed the PCB's and just found the different between the two PCB'S, the UD-1200 and the UD-1200 Pro. It's resistor R41, 2,2 kOhm (222 top marking).
R41 is present at the UD-1200 PCB. The pads are unpopulated on the UD-1200 Pro PCB.
After placing a 2,2 kOhm resistor to the Pro PCB, flashing the UD-1200 firmware, it starts as a UD-1200 with full temperature on T-245 handle. The T-210 handle is not recognized when R41 is soldered.
« Last Edit: April 02, 2024, 08:20:41 pm by JimKnopf »
The following users thanked this post: DavidAlfa
Offline DavidAlfa
So it's possible after all?
@DavidAlfa Sorry for my late response. I managed to burn Q12 somehow. It's a PNP transistor (2F marking). I was waiting for the part. Q12 switches negativ voltage to the two LM358. Has something to do with detecting a tool plugged in and temperature adjustment for the tip. After replacing Q12 i could make an image.
To answer the question, yes, it works. Both devices are now fully working UD-1200 with T245 handles at full heat.
Now i just need a newer firmware. I'm in contact with someone willing to grab the firmware from his newer UD-1200.
Offline Vasil78
  • Country: ru
« Reply #105 on: September 07, 2024, 06:31:26 am »
Good day forum members! Tell me how to fix the breakdown of jabe ud 1200. It hangs on, welcome and I can’t do anything. Can you tell me where to get the firmware for this device? Thank you.
« Reply #106 on: September 07, 2024, 07:02:27 am »
@Vasil78 What is the Firmwareversion of your UD 1200?
I would suggest desoldering the Eproms, readout/save the content for backup and clear the Eprom. Try to start the device with an empty Eprom.
Usually you can't corrupt the data inside the STM32F103 because the MCU is write protected.
Offline Vasil78
  • Country: ru
« Reply #107 on: September 07, 2024, 08:34:49 am »
 I don't know what firmware version it is
Thank you, I'll just try and see what will happen if I clear EEPROM?
« Last Edit: September 07, 2024, 08:42:50 am by Vasil78 »
« Reply #108 on: September 07, 2024, 10:13:12 am »
@Vasil78 First you have to save a backup before clearing the Eprom. You know what admins tell you? No backup? No pity!
Offline Vasil78
  • Country: ru
« Reply #109 on: September 07, 2024, 12:06:25 pm »
eeprom counted but can't erase flash drive
« Reply #110 on: September 07, 2024, 12:41:26 pm »
Did you desolder the eprom and read it with external eprom reader like T56 or RT809H? Show me an image of the eprom (to read the marking).
Offline Vasil78
  • Country: ru
« Reply #111 on: September 08, 2024, 04:41:04 am »
I read it TL866 2 plus
I can't attach a file, it gives an error
« Reply #112 on: September 08, 2024, 05:26:52 am »
@Vasil78 An image should not exceed the limit for a single file of 8 MB or up to 10 images and 8 MB for all the images. If you wan't to upload a bin file, rename it to .txt extension.
Offline Vasil78
  • Country: ru
« Reply #113 on: September 08, 2024, 05:43:49 am »
Here it is
« Reply #114 on: September 08, 2024, 06:21:39 am »
@Vasil78
I guess the Eprom is a ATMLHxxx 08CM?
Did you read out as AT24C08C?
When erasing, what voltage to you have on WP Pin-7?
Offline Vasil78
  • Country: ru
« Reply #115 on: September 08, 2024, 06:58:18 am »
I guess the Eprom is a ATMLHxxx 08CM?  yes, that's right
 Did you read out as AT24C08C?  flashed as AT24C256B it seems to be an analogue of EEPROM my programmer can not determine the name of the chip
When erasing, what voltage to you have on WP Pin-7? when rewriting there is nothing 0
 but eeprom is overwritten without error
« Reply #116 on: September 08, 2024, 07:23:36 am »
@Vasil78 0 V on WP is ok, should be pulled down to GND for write operation. The manual says 08C only uses A2. A0 and A1 are ignored and can be connected to GND.
Offline Vasil78
  • Country: ru
« Reply #117 on: September 08, 2024, 07:32:03 am »
That's right, that's what I do
Offline Vasil78
  • Country: ru
« Reply #118 on: September 08, 2024, 07:53:08 am »
What to do next?
« Reply #119 on: September 08, 2024, 10:44:16 am »
@Vasil78 I attach my Eprom readout (2 files). You can try that.
I would start with the ATMLH028_AT24C256_readout_Jabe_UD-1200_20230924-T56.BIN
Try flashing that content and resolder the Eprom. I would inspect boot process with a Logicanalyzer/Oscilloscope on the Eprom if data is read properly during boot process.
Did you try to start with the tool disconnected? A message should appear on Display "No tool found".
Offline Vasil78
  • Country: ru
« Reply #120 on: September 08, 2024, 11:11:07 am »
your firmware does not flash, it gives an error, although it reads the native one from my EEPROM and also flashes it without errors, it’s somehow strange.
« Reply #121 on: September 08, 2024, 11:14:04 am »
I assume the content just remains on your Eprom. You wrote earlier that you can't erase the content. Can you provide a logfile from flashing process? What are the steps that are sucessfully done by your TL866II+?
Offline Vasil78
  • Country: ru
« Reply #122 on: September 08, 2024, 11:27:06 am »
Yes, it is true that it does not erase the flash, but the erase button is not active.
« Reply #123 on: September 08, 2024, 11:31:49 am »
@Vasil78 seems the AT24C08C is not supported by the TL866II+ http://www.xgecu.com/MiniPro/TL866II_List.txt
It is supported by RT809H. I checked on my T56, and it is also not in the supported device list. I remember that i tried different programmers.
« Last Edit: September 08, 2024, 11:39:35 am by JimKnopf »
Offline Vasil78
  • Country: ru
« Reply #124 on: September 08, 2024, 11:49:42 am »
It's clear that the problem is with the programmer. It looks like tomorrow I'll try to borrow a T56 from a friend. We'll think about it further. Thank you very much for your time. I'll write tomorrow.
