Author Topic: JBC BT-2BQA buzzing sound  (Read 489 times)
Offline gaminnTopic starter
« on: December 25, 2024, 10:19:07 am »
I got a brand new JBC BT-2BQA soldering station and when it is heating the tip, it produces quite loud buzzing sound. https://youtu.be/sXBanCWsp00 - please turn your up volume as my phone is not able to record a quality sound record.
Anyone with this soldering station - is it normal?
Offline thm_w
  • Non-expert
Re: JBC BT-2BQA buzzing sound
« Reply #1 on: December 27, 2024, 08:26:57 pm »
Can't hear anything at all. Maybe use your phone and a FFT app to see what frequency, 60 or 120Hz I would guess?
What if you set the station on top of something soft?
Offline Electro Fan
« Reply #2 on: December 30, 2024, 09:48:06 am »
thm_w,
Sorry for off topic, but you have a JBC BT-2BQA and some/several JBC clones?
Offline thm_w
  • Non-expert
« Reply #3 on: December 30, 2024, 09:30:25 pm »
JBC clones only, hakko fx100, fm203, metcal mx5200/5000/ps2e, genuine.
The following users thanked this post: Electro Fan
Offline Shock
« Reply #4 on: December 30, 2024, 11:01:51 pm »
Inductors like lose coils, cracked core, bad soldering or lose transformer iron core laminations, capacitors including filtering.
As power, lighting and equipment noise can also contribute, isolate to another building and retest first.
« Last Edit: December 30, 2024, 11:06:08 pm by Shock »
Offline Hydron
« Reply #5 on: Today at 10:12:21 am »
This station uses phase angle control for regulation, and any loose ferrous objects (e.g. bits of steel wire that have rolled under the station) can cause buzzing in the leakage field from the transformer.
If there's nothing in the vicinity maybe pop it open to check for a loose screw or something? If it's the transformer itself you may be out of luck.
