Regarding tip wetting, there is one advantage to the wetting characteristics of the JBC iron.
Background: moving from cheap Velleman station to a Hakko, I went the opposite direction. I had to get used to a tip that sucks up solder... everywhere, all the time.
With a "JBC" type tip, you can wet the parts you want to use, and the solder stays there. At least that is how I used my Velleman iron. So with a conical tip, for instance, I can put some solder on the very end, and it WON'T automatically suck up, away from the tip. Now, to be sure, after using the tip like this for a short while, it oxidizes and will no longer take solder on those dry spots without some work at it... and definitely expect a decrease in tip life.
But for sure, there are a lot of disadvantages, esp with production type soldering, drag soldering, et al. At the time I used the Velleman, I was mostly hacking up prototypes and one-offs, and esp considering the minimal tip selection of the station, the "poor-wetting" was an overall advantage in this scenario. I had a conical that tinned only a few mm on the very end, and it worked for years, albeit the tinnable area very slowly but constantly shrunk, and it would have eventually needed replacement (if it hadn't corroded and broken apart from the inside that contacted the heater, first).
But first switching to Hakko, there were definitely some things I couldn't do, as well. Namely fine, point soldering of bodge wires without undoing the other bodge wires in the process. Until I discovered Hakko TFO tips from 1 to 3mm. With these, the Hakko does everything better, and I can use all my old tricks, plus some very great new ones. I've looked at Ersa tips, and I don't see that they have any TFO, so...
The more you get into the process, the less often you need to do bodge wires... but I can't give up TFO tips. I think I'll always have an 888 kicking around, no matter what else I ever buy. It doesn't help that ironically I find the 2.5 to 3mm TFO tips to be some of the most useful production soldering tips made.
