Author Topic: JBC or ERSA? Mini-review: demoing a JBC system but not convinced.  (Read 18652 times)
Online Shock
Re: JBC or ERSA? Mini-review: demoing a JBC system but not convinced.
« Reply #50 on: October 17, 2019, 01:17:42 am »
I decided to update my equipment to a Pace MBT350 (3 channel Intelliheat series) and two Pace ADS200 (1 channel Accudrive series) stations last year. Pace is still in the middle of releasing Accudrive handpieces and stations so if you are after the latest and greatest all in one solution there will be a wait. I'll try to summarize what I have setup most of the time.
Pace MBT350 (price varies on config):
SX100 - Vaccum desoldering. If not the best desoldering tool out there. Can be setup to run with virtually no downtime. Handle or pedal actuated, has anti clogging features, fast swap dross reservoirs.
MT100 - Mini tweezers. Fast swap tips, powerful, cheap to run and solid. New Accudrive model being released MT200 is 120W and is aluminum constructed with silicone grips, should be even better. Dave will review soon.
TJ70 - Precision hot air. Handle or foot actuated. It's convenient precision air for smd work, not a replacement for a BGA hot air setup.
Pace ADS200 (price starts from around $220):
TD200 - Soldering iron. 120w fast swap tips, calibration free, aluminum construction, 3-4s fast heating on smallest tips. Has advanced power features. Very simple to operate. Combines smd tips and high power tips into the one iron. Ergonomic and short grip to work distance. Affordable high quality cartridge tips ~$11-$13.
I would have gone for an Accudrive multi channel station if it was released but currently this setup is the best of both worlds till the Accudrive series is finished. Pace balance longevity/performance/price over plastic, fancy displays. But as for technology the new Accudrive series has advancements over other brands.
Below are shots of handpieces and what the stations look like on the bench. Don't expect fancy displays here. These displays are designed to run with continuous duty for years and even if failed can easily be replaced. The strain relief for the irons is built into the handle btw.
« Last Edit: October 17, 2019, 06:00:42 am by Shock »
