Here are pictures of my 858D+ to show differences between 110V and 220V heaters. The coils are thinner for 220V. I think the KSGER uses the same handle.
Which part did you replace? Was it the entire handle, or just the heater?
The heating module has 4 wires- two for the heater and two for the thermocouple. Polarity is important with the thermocouple wires, or else the temperature reading will be incorrect. The (+) wire has iron and is magnetic, and colour can be mixed, red or yellow some are blue. It's a mess.
If you changed the entire handle, the pinout might be different at the connector. A "GX16-8" is the name of the connector to the handle, not a model number.
