Usually the hot air gun nozzles are straight, that is the end part of the nozzle is just a straight pipe (i.e. you can see through its hole)
However, I've seen some nozzles that on the inside have kind of 'spiral', so the blowing air at the center of the nozzle instead of exiting directly through the pipe would probably start 'whirling' around before passing to the exit pipe.
Are those nozzles useful, and in which situation?
