Author Topic: KSGER soldering station with 12V C210 JBC tip  (Read 971 times)
Offline cosmin1
« on: January 05, 2021, 05:02:09 pm »
I would like to talk here the options for JBC C210 tip to work on KSGER controller.
Especially about the power supply options.
I tried to adapt this 24V supply by replacing R5 with a smaller value, but it's not stable at 12V.
Tried this with the 6A blue board too, but same problem.
« Last Edit: January 05, 2021, 06:52:31 pm by cosmin1 »
Offline DavidAlfa
Re: KSGER soldering station with 12V C210 JBC tip
« Reply #1 on: January 06, 2021, 03:47:54 am »
The problem is that the controller gets its own power from a secondary.
If you lower a lot the output, the controller will also receive less voltage, and trigger the Under voltage protection. And it will start oscillating.
You  could power it with a small 12v charger. Then it shouldn't have much problem.
« Last Edit: January 06, 2021, 03:49:59 am by DavidAlfa »
Stm32 soldering station firmware: https://github.com/deividAlfa/stm32_soldering_iron_controller
Want support for your board? Put detailed info in the forum and get ready for testing. Issues? Before reporting, always flash the latest github FW and make a full reset.
Please use the forum, don't PM me!
Offline cosmin1
« Reply #2 on: January 06, 2021, 07:10:39 am »
The controller under voltage protection is not a problem. You can set the level at lower value, so it will work fine at 12V too. Mine it actually work with 12V.
Problem is the power supply itself. I want to use in the same case, with a 83x83mm power supply, not with external one.
Offline DavidAlfa
« Reply #3 on: January 07, 2021, 12:32:03 pm »
How to youy know that? If you say it's unstable... what happens? goes crazy to ex. 15V, then to 6, then to 15?
Thatis what happened to me when I tried exactly that few years ago, trying to get 5V from a 12V adapter.
Measured the controller VCC (It's live connection, be careful) I clearly could seehow it got to 12V, then to 8 and the controller resetted.
The controller datasheet said that minimum VCC was 9V, so that was the problem. Or you change the aux secondary with more turns, or you set higher voltage
Offline DavidAlfa
« Reply #4 on: January 15, 2021, 06:01:21 am »
Remember that you can adjust the max pwm duty in the settings.
Set it to 25% and the power at 24V will be equivalent to 100% at 12V.
Offline floobydust
« Reply #5 on: January 15, 2021, 06:26:28 am »
That power supply is apparently not so great, this guy did a bunch of mods to get it stable and low EMI just for 25V. They up-sized the mains capacitors from 2x22uF to 2x47uF, output capacitors to 3x820uF, added 0.1uF ceramics and more.
https://translate.google.com/translate?sl=auto&tl=en&u=https://mysku.ru/blog/aliexpress/72410.html
Offline DavidAlfa
« Reply #6 on: January 15, 2021, 12:50:19 pm »
Hah.. Imagine the ripple then when using the JBC and using 200% of the specified power  :-DD
The fact that it doesn't blow up is already remarcable
Offline bozza
« Reply #7 on: January 17, 2021, 10:42:07 am »
Is it perhaps possible to build some sort of adapter to have JBC handles and tips,with all the electronics inside the adapter?
Offline cosmin1
« Reply #8 on: January 20, 2021, 09:36:12 am »
I already upgraded the capacitors to 2x47uF. It's ok for 24V, but when modified can't deliver stable 12V output (it varies 3-4V around 12V).
So i just found a 12V power supply and hope to solve it.
That is available only on your fw. The KSGER fw doesn't have such a setting.
« Last Edit: January 20, 2021, 12:03:04 pm by cosmin1 »
