Author Topic: KSGER T12 menu option help needed  (Read 186 times)
Offline Paul-H
« on: April 21, 2021, 08:52:36 pm »
Hi all
I have one of the KSGER T12 v3.1 soldering stations and have managed to figure out most of the menu option but one I am struggling to understand.
The option for Code End
First option is to select which sensor is used to measure temperature, the one on the processor board or the one in the handle, which would be the better option to select. ?
Second option is for a temperature adjustment going from 0 to 100
What is this adjustment for ?
Is it as simple as it's measuring the ambient temperature and needs to be adjusted to a known good temperature reading for the room.
The default setting is 24c
Thanks for any help with this
Paul
« Last Edit: April 23, 2021, 10:28:32 am by Paul-H »
