Author Topic: KSGER T12 STM32 V3.1S soldering station  (Read 28400 times)
Offline bozza
Re: KSGER T12 STM32 V3.1S soldering station
« Reply #50 on: January 17, 2021, 10:54:17 am »
What is the point of having desoldering options if a pump doesn't fit into the case?
Has anyone successfully been able to use jbc handles and tips?
It would be nice if you could use both hakko and jbc handles, perhaps through an adapter.
That way you wouldn't need to buy 5 million different soldering stations.
Offline mastershake
« Reply #51 on: February 24, 2021, 12:14:41 am »
here is the v3.1x hex file this has a different branding "wlida" and corrected the error with the calibration of VSM2 see attached for those that need it. this can also allow you to flash back to stock from the custom ones. other then the above changes this is identical to the ksger. this works on 101, 102 and 103 v3.0 (both styles of battery on board or attached via a lead) and the v3.1 oled boards.
The following users thanked this post: khayman, schwaggins
Offline mastershake
« Reply #52 on: March 29, 2021, 11:48:45 pm »
new psu in the newest shipped ones. v2.05 now. they moved the one trace under the heatsink and a few other components but not to many other differences  the one larger heatsink on the one i just got in was mangled sadly warped and twisted pretty bad ill unmount it straighten it out and re mount it, there is also no paste or material on either sink on this one. ill get some pics as soon as i can.
Offline nanolab
  • Country: lt
« Reply #53 on: May 06, 2021, 05:20:12 pm »
There is a problem, before this was not. The station works well, but there is a ticking sound and a green LED is blinking on the control board.
Offline Lemaru
« Reply #54 on: June 04, 2021, 08:48:37 pm »
I haven't seen many other posts about the v2.05 PSU other than this one. I assume this means no more having to mod the heatsink to make it safe? Is there any other fixes required for this version?
Thanks
Offline Polter
  • Country: gr
« Reply #55 on: June 06, 2021, 07:13:14 am »
I've received my T12 about a week or two ago. It has the new v2.05 PSU so I'll post some photos. As you can see there's no battery attached any more. Let me know if you want any new photos or clarification.
Offline Lemaru
« Reply #56 on: June 07, 2021, 08:49:34 am »
I also got mine a few days ago. V2.05 PSU, but mine does have a battery fitted and stuck on top of the transformer
