Following up on my mini review, mostly of the handle. I wanted to confirm that when I played around with it tonight, the tip I had used before worked right, right from the start. The display did not "dance" between "error" and displaying temperature, so I suspect it only happens to new tips. This is somewhat confirmed that I swapped tips hot for the second tip that came withe unit and that tip did cause the display to "dance" until it finally settled, just like the first tip. Other than the handle not having the positive feedback to let me know the tip was seated, the handle works well. Pushing the tip in until it stops seems to work. There's no disconnection while waving it or when I tested the tip temperatures, about the closest to soldering I have done with this set, yet.
A mini-review of the soldering station itself, since I had some time to look through the menus and test out the interface some. I will admit, I need to d/l the manual and read through it, the interface is NOT user friendly. In my shop, since I do a lot of woodworking projects, painting, general mechanics stuff, I prefer to have as few buttons on things as possible to press because my hands are frequently dirty with glue, oil, paint, etc. so the fewer buttons on things the better. However, I think this unit could use a couple of buttons to take some relief off the push/rotary dial. I mean pushing in and turning left or right while holding the knob in is kind of a pain. Having a "Back" button to back out to the main menu would be great rather than holding the knob pressed in for several seconds to accomplish the same thing. As pointed out in another thread, it appears under the Tips menu that the firmware supports JBC tips. If that is the case, and the tip numbers that I suspect are JBC tip numbers are in fact JBC numbers, then all those tips are just jumbled together, so you have a fairly long list to scroll through with no order, although most T12 tips seem to be grouped together, there are the suspected JBC tips between the groups of T12 tips. KSGER should have added submenu's and grouped the T12 tips in one menu and the JBC tips together in another menu. And a third menu option for keeping the user defined tips settings in. Anyway, other than those nit picks, the unit seem to work well. As mentioned earlier, I did not actually solder anything, but checking the tip temperatures on a Hakko FG100 clone, seemed to agree with the first tip's temperature reading on the KSGER (the K tip), but the second tip was off by about 30 degrees C (DL32). The active tip selected, however, was the default,B1, once I figured out how to change the active tip to DL32, the temperature reading was pretty much spot on (about 4 degrees C different). I did not re-check the K tip with the active tip set to K.
