If you expand the bottom picture you will see the reason for confusion printed on the wiring labels . I don't know how it should be wired so I assumed red to be pos black to be neg and white to be the output . . I have a power supply up to 5 amps and the LED is just to test them .
I see your point though and did try different setups without response.
