Author Topic: Longwei K3010D constant current quircks  (Read 146 times)
Offline vizkoze
« on: March 21, 2021, 02:09:53 pm »
Hi, newbie here so please be patient...
I recently modified my longwei K3010D power supply to reduce the switching noise as I found some instructions on youtube and this forum https://www.eevblog.com/forum/projects/getting-rid-of-excessive-switching-noise-on-the-longwei-lw-k3010d-bench-supply/msg2894656/#msg2894656.
That worked like it should. While testing the unit under load in constant current, i found out some strange behaviour and couldn't find any thread that described this issue so i'm starting this one.
What I did: I loaded up the powersupply with some 8ohm 100W resitors and applied a constant current. After a while the fan kicks in to cool the swithing mosfets and I notice a current drop of around 160mA on the output of the supply.
What use is a constant current mode if the power is measured before the output and takes into account internal components?
Is anyone else seeing this behavior?
I thougth it might have something to do with the modification (placing an RC filter on the gates of the swithcing mosfets) but I undid the mod and the behaviour was the same.
I found the schematic of the board LW-K3005D-1 but as I'm not an EE, im turning to you guys.
Would there be a possible mod to remove the current of the fan from the CC measuring circuit?
Greets
