How to youy know that? If you say it's unstable... what happens? goes crazy to ex. 15V, then to 6, then to 15?
Thatis what happened to me when I tried exactly that few years ago, trying to get 5V from a 12V adapter.
Measured the controller VCC (It's live connection, be careful) I clearly could seehow it got to 12V, then to 8 and the controller resetted.
The controller datasheet said that minimum VCC was 9V, so that was the problem. Or you change the aux secondary with more turns, or you set higher voltage
