Do you want to extract the fumes from the room, filter the fumes, or assist in displacing the fumes into the well ventilated room? (it is well ventilated right?)
For the occosional solderin job, the last one will suffice. For production soldering you'd want the first one. For occasional production that varies location, a filtered solution should work.
