Hi.
I have been looking for a power supply for a project that I might be doing to help out a local business. All or most of the components I need I have found easily...except one, the power supply. I have linked in the data sheet to the board that I need to power, but I have not been able to find a power supply that meets the chip and my requirements.
The input voltage need to be min. 3.2v and max 4.3v with a typical at 3.7v DC. And current need to be min. 1.5 amps and max 12 amps with the typical current being 6 amps. I would like to find something that is as close to the typical 3.7v DC as possible but the higher the current output the better since I am planning on powering at least 4 of these from one power supply.
I first looked into a normal PC power supply (300w) but all that I saw is that they have a 3.3v and 5v supply. Not going to cut it.
I would prefer to just buy a power supply that will work for this, but if I have to I am willing to try and make my own if someone has and thoughts on how to do that or would it be easiest to try and just step down the 5v from a normal power supply?
Any advice and guidance on this would be much appreciated.
Link to data sheet.
http://www.evolvapor.com/datasheet/dna30.pdf
