Author Topic: Hakko 950 vs fx-8804 Tweezers same product different connector?  (Read 447 times)
Offline yo0Topic starter
  • Country: mx
hello, i have a fx-888, can i use the 950 with it changing just the connector?
best regards
Pio
« Last Edit: April 13, 2025, 10:52:36 pm by yo0 »
Offline thm_w
  • Non-expert
Re: Hakko 950 vs fx-8804 Tweezers same product different connector?
« Reply #1 on: April 14, 2025, 09:54:44 pm »
Its not clear what you are asking.
HAKKO FX8804-01 Hot Tweezer for FX-888D, FX-889, FR-701, FR-702
I wouldn't bother with those, spend the money elsewhere.
  • Country: mx
« Reply #2 on: April 14, 2025, 10:13:09 pm »
I will try to explain better, y have a fx888 (non D)  station, someone sells a new 950 hot tweezer, really cheap, i see the connector is different than the one on the recommended fx8804 tweezer, my question is if I can use it if i change the connector, visually seems both tweezers are the same except for the connectors.
Best regards
Offline thm_w
  • Non-expert
« Reply #3 on: April 14, 2025, 10:22:05 pm »
"The Hakko 950 is compatible with the Hakko 936, 937, 939, 703, 926, 927 and 928 stations."
https://kb.hakkousa.com/Knowledgebase/10581/Are-936-and-FX-888-Heating-Elements-Interchageable
Hakko says its not compatible, might still work at a lower power draw.
  • Country: mx
« Reply #4 on: April 14, 2025, 10:45:57 pm »
Thank you very much
Best regards
Offline floobydust
« Reply #5 on: April 17, 2025, 09:23:18 pm »
Yes you can use Hakko 950 tweezers with an FX-888 station.
Same connector and pinout. The difference is the FX-8804 is rated 26VAC 65W but the 850 is 24VAC 50W.
The FX-888 base puts out more power than the 936. So you would be overpowering the heater a little bit during warmup I think.
The following users thanked this post: yo0
