Author Topic: Magnetic Materials Tester  (Read 357 times)
Offline ornea
« on: June 03, 2021, 02:50:50 am »
Picked this up from the local hackerspace hackme bench.
Anyone any ideas how to use it or what other tasks it might be useful for.
Online coppercone2
Re: Magnetic Materials Tester
« Reply #1 on: June 03, 2021, 02:57:43 am »
you characterize a magnetic material inside of some fixture that connects to the device, its likely meant to measure transmission parameters across frequency and temperature and field strength
probobly specially made to catagorize magnetic mixtures from someones manufacturing process (they have a prototyping plant to make a unique composition)
« Last Edit: June 03, 2021, 02:59:38 am by coppercone2 »
Online Berni
  • Country: si
« Reply #2 on: June 03, 2021, 07:19:40 am »
It seams like it can apply a AC current at a selectable frequency while also interfacing with a thermocouple.
Since it has a heater switch too i would assume that this connects to some test fixture that heats a sample while measuring its magnetic properties using a induction coil. Likely used for finding the curie point of a alloy sample.
So not really all that usefull, but you can tear it apart for some nice pots, switches, knobs and a nice transformer.
Offline ornea
« Reply #3 on: June 03, 2021, 07:29:51 am »
@Berni, have since been considering turning it into a T12 soldering iron station.  As you say its got pots, thermocouple J K amplifier, heater circuit, PSU and transformer with many taps.  Maybe jam a ESP8266 in there to read the output of the thermocouple and control the heater.  Just not sure how to read the pot position as only a single ADC,
Online coppercone2
« Reply #4 on: June 03, 2021, 07:50:24 am »
i think its curie point now
Offline ornea
« Reply #5 on: June 03, 2021, 08:01:09 am »
@coppercone2 curie point checker, that sounds very plausible.  It looks like it came from a place of educat'n
« Last Edit: June 03, 2021, 08:02:47 am by ornea »
