Hi all,
Today a neighbor of mine gave me a Einhell Euro 1500 E compressor, it's a 24l 8 bar compressor.
The compressor is a bit rusty, with some paint falling off when I clean it, so I plug the thing to see if it would start, and it start
Now the bad thing, on the output of the compressor it uses a Condor MDR 1/11ea pressure switch with start & relief valve system <
https://www.condor-usa.com/mdr1-11-ea-212140 >, which is broken it have a crack so it loses air so the compressor is almost always running to compensate the leak.
Since it would be useful to have the compressor in here, to clean the bench and to use on other stuff around the house or car, I thought of using it for a desoldering gun.
I was looking to buy a cheap desoldering station, but I've a Metcal MX500P-21 so it was just add the MX-DS1 gun and could use the compressor for the ventury.
I've to replace the Condor MDR1/11ea switch, since he's crack, but what should I use after that to regulate the pressure and flow?
Do I need a filter for the air/oil? of what type?
Anyone with experience on this?
