Author Topic: Minipro programmer issue on new version  (Read 874 times)
Offline hfarinha
« on: October 14, 2022, 08:36:04 pm »
Hello,
I own a Minipro TL866CS for quite a while and I mainly use it to program EPROMs and EEPROMs (2732/28C64) and so far never had any major issues using it.
Recently I decided to pull the trigger on the model TL866 II Plus (Now re-branded to XGecu TL866II Plus)
I downloaded the latest version of the Windows software and the firmware was upgraded to the latest one which I believe is v04.2.132.
With the new programmer I'm having issues programming the very same ST M2732A EPROM chips that I programmed so many times with the TL866CS.
I usually use the programmer under linux with the 'minipro' software so here's the output of both:
TL866CS
$ minipro -p M2732A@DIP24 -w test.bin
Found TL866CS 03.2.86 (0x256)
VPP=21V, VDD=5V, VCC=5V, Pulse=500us
Writing Code...  5.26Sec  OK
Reading Code...  0.14Sec  OK
Verification OK
TL866 II Plus
Found TL866II+ 04.2.132 (0x284)
VPP=18V, VDD=5.5V, VCC=5V, Pulse=500us
Writing  Code...   0%
Verification failed at address 0x0000: File=0x06, Device=0xFF
Also worth to mention that under the Windows software I have the same issue. I never tested programming the chips with the firmware that came with XGecu TL866II Plus so I really can't confirm if it would work or not (it was only a few minor versions below).
Thanks in advance.
H.
Offline Dilbert66
    • Dilbert66's Projects
Re: Minipro programmer issue on new version
« Reply #1 on: November 25, 2022, 04:06:06 pm »
It's  known issue with the Tl866II plus regarding 2732's. Here's a link to my post on the subject. Includes  work arounds for adding 21v or 25v and programming 2732's
https://www.eevblog.com/forum/testgear/modification-to-add-the-missing-21-and-25-volt-vpp-ranges-to-your-tl866ii-plus/msg3959678/#msg3959678
Offline hfarinha
« Reply #2 on: November 29, 2022, 09:06:35 pm »
thanks for this. I think I'm keeping my TL866CS for now.
Offline xmris
« Reply #3 on: November 30, 2022, 11:30:59 am »
@OP just FIY , the Xgecu (windoze) s/ware works under linux well via 'wine', needs just a patched DLL file and some work with the udev rules.
BTW I have no experience with those 21/25v EPROMs , just used with 27cXXXs ones.
READY.
