I used a monitor stand with my HDMI microscope.. pretty happy with it, though I had a table stand to start which I drilled to match the vesa mount and bolted it in place...
First question would be how much does your microscope weigh? Then if you find a monitor stand to handle that much, plus the weight of whatever you need to add to attach the microscope to the monitor stand, I guess you'll be fine.
