I got some cheap china hot tweezers bundled with a T12 comparable soldering station.
Mainly because I needed to remove a few 100' 1206 caps from 6 layer 3oz copper pcbs.
It worked better than using my single good quality iron (Thermaltronics), around 2 sec vs 10 sec.
And it cost about 1/2 the price of the hot tweezer attachment that could plug into my Thermaltronics.
I'm quite satisfied that hot tweezers are useful and worth while having, when my cheap china ones die i will definitely be ordering the Thermaltronics version.
The cheap china ones work fine, they just feel cheap and plasticky. I'm sure the tip coating wont be as good, but no sign of issue yet.
The exact listing/seller I got has disappeared, but this is what I got
https://www.aliexpress.com/item/1005005223425785.htmlSo all in all I would recommend getting some hot tweezers if you need to desolder passives a lot
