Well, the "*" probably means a demo mode... But I wonder why there is no expire date shown.
Some hints for your drawings: Make a single line. The oscilloscope needs a continuos signal wave, so you need to make sure your drawing contains only one line Use only straigth lines in SVG files. At this time, Rabiscoscopio cannot read SVG with splines, circles or Bezier curves If the oscilloscope starts showing a diagonal line, try hitting the XY button a few times until it syncs with the audio signal. It just supports straight lines. That means that you can't use curves/circles/splines/bezzier on the final drawing, yet. But you can use them on Inkscape and convert them to straight lines when you've finished your drawing. Just hit the button and then select the curve. Then you hit the 11th button on your toolbar, called "Make selected segment lines", and your curve will be converted into a series of connected lines.
