Ah, I finally found the fault.
First of all, I were looking around for anyone uses the UEi DMM like me. I gave up after tens of search result pages from Google.
However, I read one paper (
http://electronickits.com/kit/complete/meas/m-2665k.pdf) that introduce how to assembly the DM kit, in which a shield spring is soldered onto the board. I doubt that the shield spring plays some role in DMM.
Look back my UEi, I found 1 spring in the front side (side with LCD) while the back side there is no spring. On back side, however, I saw an SP1 sign next to the open round-shape area which I inferred would be reserved for another spring. There should be two springs in my UEi.
Then I opened the Dave's #99: 100$ MM shoot-out (
http://www.eevblog.com/2010/07/11/eevblog-99-100-multimeter-shootout-extech-amprobe-bk-precision-ideal-uei-uni-t-part-1of2/), quickly scrolled to the "take it apart" with UEi DMM. Got it right there! In the video, there are two springs, one in front, another in the back. Then, one spring might be lost in my UEi.
I used a spring taken from a pen to the SP1 place on the board. And surprise, the DMM works again.
Very strange that after I tried to take the spring off the board, my UEi continues working.
I will check if that little spring is truly the cue for my UEi DMM problem?
I still have not known the purpose of those shield spring(s) in DMMs yet. Will study later.
Any comment?
Thanks
HT
