Author Topic: Need help grounding my DJ gear.  (Read 3176 times)
Offline Mint.Topic starter
  • Account is inactive now. Thanks everybody!
    • Personal Blog, Mint Electronics.
« on: October 29, 2011, 12:27:28 am »
Hey guys I recently got some DJ gear, however the problem is there is a small grounding knob at the back and I have no idea what to connect it to. Please help me out, thanks!
Personal Blog (Not Active Anymore), Mint Electronics:
http://mintelectronics.wordpress.com/
Offline DrGeoff
    • AXT Systems
Re: Need help grounding my DJ gear.
« Reply #1 on: October 29, 2011, 01:08:12 am »
My son has one of these Audioline MDEX3 units as well. The unit is double insulated and has no safety gound connection. This little thumbscrew is for attaching the shield wire of your external turntables if you use the phono option.
« Last Edit: October 29, 2011, 03:07:22 am by DrGeoff »
Was it really supposed to do that?
« Reply #2 on: October 29, 2011, 02:19:38 am »
Oh perfect, thanks for the reply!  :D
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #3 on: October 29, 2011, 11:09:43 am »
The ground lug is a relic  of ancient times.
Then, when you where hearing some "buzz" from the speakers, you started to wire the ground lugs  together, in any order, trying to kill the "buzz".
I think that now it  has no more reason of being there, if not for some analog turntable..
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline DrGeoff
    • AXT Systems
« Reply #4 on: October 29, 2011, 11:51:43 am »
The DJ unit has phono inputs and RIAA preamps, switchable from the line inputs. The GND is still required with these low level sources, unless you are using a properly balanced phono stage, which are very uncommon.
