Author Topic: Need help identifying a soldering nib  (Read 3326 times)
Offline YoshitoSakuraiTopic starter
« on: January 03, 2018, 06:17:21 pm »
Good Morning,afternoon or evening depending on where you're from,
*go to the next * for my actual questions - the story hehe.
Recently I've been getting into electronics with this new hobby or for some even life I have purchased some ''beginning'' crappy soldering irons they obviously didn't last me long because they were pretty  :phew: to use so i began contemplating on buying a new proper one.
On a sunday i saw a portable soldering iron for 10Euros i was like... might aswell give it a shot if its bonkers ill just save up a bit and buy a proper one. The one i bought for 10 euros at an local ALDI actually worked out pretty well for me it was small, had a battery so i could use it around the house or cars/model aircraft ( even used it at school where i study avionics for aerocraft shh dont tell the teacher) Sadly afther using it for a while the soldering nib/tip obviously weared off it usses some kind of propriatary nib/tip.
**My question is does someone here know how i can obtain these Nibs? Pics:
 https://i.gyazo.com/3790ed9989abb39a0ee34aba0e2c7d6b.png
https://gyazo.com/ba27a581a4f1770f1cb3c6cb99029dd4
https://gyazo.com/fc57054012dec720acb445f17e5b2620
https://gyazo.com/a1c9506c60b1c0afb66b3c06727e329c
https://gyazo.com/431da8244c4635d798bf7f2aef020f6b
https://gyazo.com/539d391939427e3f3dc0db78de3133cd
If one does not know where to find these i would also be fine with a entirely new portable soldering tool with standard nibs.
Thank you for your time  :-+
Offline tooki
Re: Need help identifying a soldering nib
« Reply #1 on: January 04, 2018, 02:26:18 am »
No offense, but it didn't occur to you to google the name of the vendor (Grizzly Tools GmbH), printed right on the label?!? I did, and the first result is their homepage, the second one their online store. 10 secs of clicking and boom, here's the page with spare parts for it: https://grizzly-shop.de/LK-Parkside-PLKA-36-A1-283231_1
« Last Edit: January 04, 2018, 02:27:49 am by tooki »
The following users thanked this post: YoshitoSakurai
Offline kalel
« Reply #2 on: January 04, 2018, 04:17:41 am »
If you are familiar with this already, you can ignore the advice.
After each soldering, it helps to coat the tip with some solder just before or after you turn the iron off. The same could be done when taking breaks as well.
This can help the tip to last much longer, as it has a protection layer against oxidation. As for cleaning (just before the soldering), you can use brass shaving type of tip cleaner, or a wet sponge, or even both. Just make sure that the iron is not left on for a while without any solder on it.
For me, those tips have significantly improved tip lifetime of very cheap soldering irons.
The following users thanked this post: tooki, YoshitoSakurai
« Reply #3 on: January 05, 2018, 10:33:11 pm »
Ahh I actually havent stumbled uppon this tip yet. I shall be doing this since it makes a ton of sense thank you for this tip!~.
-Yoshito
« Reply #4 on: January 05, 2018, 10:39:04 pm »
Thanks for the help!~
Actually I haven't thought about this at all I've yet to have anything break for me in this lifetime ( only 21 ) that was a quality item and i wanted to get fixed instead of replaced. Not that this item i was talking about is quality haha...
But i shall take your post as a tip for future reference thanks again.
Yoshito
