Author Topic: New Aixun T380 LiPoly 80W Soldering Station  (Read 689 times)
Offline SteveyGTopic starter
  • Soldering Equipment Guru
« on: April 25, 2024, 08:26:24 am »
Aixun recently released a new portable station, the T380
https://www.aixuntech.com/product/t380-portable-smart-soldering-station-with-t210-t115-handle-welding-tools/
https://s.click.aliexpress.com/e/_DFbqYEb
It looks like you can power the station from the included USB-C power supply, or run it from the replaceable lithium-ion battery if you need to work away from your work bench.
It's surprisingly heavy, but appears to be fairly thick completely metal construction.
I should have a video on Monday
« Last Edit: April 26, 2024, 04:45:15 pm by SteveyG »
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
The following users thanked this post: ddrl46, thm_w, hasbihal
Offline thm_w
  • Non-expert
Re: New Aixun T380
« Reply #1 on: April 25, 2024, 09:32:09 pm »
The nice thing about that is you could use a low power adapter and have it charging constantly (<20W), and should still be fine for most use cases.
They are saying 80W, so 40W+ from each 18650, or about 11A each... ah hope those are good quality cells.
Though I actually hope that spec is BS, driving a C210 at 80W is not necessary at all. 40-50W is fine.
JBCs portable unit is specified at 24W: https://www.jbctools.com/biron-500-tool-precision-handle-product-2512.html
edit: better be an earth port on this I don't see one in the photos  ???
« Last Edit: April 25, 2024, 09:37:13 pm by thm_w »
Re: New Aixun T380
« Reply #2 on: April 26, 2024, 04:44:55 pm »
The following users thanked this post: thm_w, Astray
Re: New Aixun T380
« Reply #3 on: April 26, 2024, 04:45:59 pm »
No ESD point, I missed that.
