I bought my anti static mat from Aliexpress, long time ago, from a huge roll (the material was mostly flat, curved a little towards the downwards, not upwards, and it flattened itself with time, standard width and you can order as many meters as you need). You have to wash it first, then wait a few days for the rubber smell to go away.
https://www.eevblog.com/forum/reviews/anti-static-mat-smell/msg1022725/#msg1022725Make sure you buy a rubber mat, not a vinyl mat. Rubber mats can withstand a (continuously) heated blob of melted solder, and can withstand to accidental piercing or cutting. Vinyl mats instantly melt when touched with a hot soldering iron, and are easily cut and pierced by any metal tools.
Aside from that, my advice is to NOT get a mat at all. Use just a big sheet of white paper as a mat, or reuse the back of a wall calendar page, etc. Unless you are in a very dry climate and wear rubber boots on synthetic carpet, you won't need any anti static mat or anti static bracelet.
But if you install a mat on your bench you'll have a huge thermal mass, and charge mass in the mat itself, which will always influence your circuits (will couple with the circuits under test and will induce extra hum and other noises). And it has some thermal inertia too, so you may get strange effects for thermally sensitive circuits. And it has a color that will make harder to spot components and tools laid on the bench (when compared with a white background bench). And, most of all, if you touch the mat with the hand, any sensitive circuit will feel that too, capacitively. And you have to clean it. And with time will get ugly stains (while the sheet of paper is consumable, can be replaced after a while). Plus, if you use a paper instead, you can lift the paper and throw away all the bits of wire (and garbage leftovers) from the desk, cleaning the bench instantly.
An anti static mat is a royal pain, and for no real benefit (unless you want to protect your bench against acid spills, which is mostly never needed in electronic work). I have an anti static mat laid on one of the benches, but I avoid that bench, I don't use the anti static mat. I use A3 or A4 paper instead, and replace the sheet of paper with a new one when it gets too dirty.
