Also, while clicking through the Pace website to try and find more detail (without success) on the Plus upgrade, I came across this news post: https://paceworldwide.com/news/mbt450-rework-system-available-summerThe MBT450 is real! It was originally promised years ago(...)
Access deniedYou are not authorized to access this page.
August 2020(...)Coming Soon: MBT 450 Multi-Channel Soldering & Rework System (available early next year*)
https://paceworldwide.com/news/pace-product-announcements-august-2020QuoteAugust 2020(...)Coming Soon: MBT 450 Multi-Channel Soldering & Rework System (available early next year*)*Next year was 2021. :-/
I have a Pace ADS200 with FW1.2 and I think I may want to upgrade that to a later one.Is this a reasonable thing to do, and how do I go about it?I bought it from Welectron in Germany january 2019.
It turns out Pace has a European rep, Factronix.They have offered to help me out with the FW upgrade.So, hopefully all will be sorted in a little while.
A couple of questions about the ADS200:Has anybody tried retrofitting a setback microswitch on a non-isb handset cubby?My new ads200 came with a non-isb cubbyAnd does anybody know what connector type is used for the handset power and control cable?
Quote from: n3mmr on November 27, 2024, 04:05:55 pmHas anybody tried retrofitting a setback microswitch on a non-isb handset cubby?My new ads200 came with a non-isb cubbyIt's been done. Google for the pinout.Quote from: n3mmr on November 27, 2024, 04:05:55 pmAnd does anybody know what connector type is used for the handset power and control cable?You just mean what the handpiece connector is? Amphenol C091B is what they use, Binder 678 series is compatible.
Quote from: n3mmr on November 27, 2024, 04:05:55 pmA couple of questions about the ADS200:Has anybody tried retrofitting a setback microswitch on a non-isb handset cubby?My new ads200 came with a non-isb cubbyAnd does anybody know what connector type is used for the handset power and control cable?Can you not use the base of your old ads?
Quote from: pope on November 27, 2024, 05:22:22 pmQuote from: n3mmr on November 27, 2024, 04:05:55 pmA couple of questions about the ADS200:Has anybody tried retrofitting a setback microswitch on a non-isb handset cubby?My new ads200 came with a non-isb cubbyAnd does anybody know what connector type is used for the handset power and control cable?Can you not use the base of your old ads?I still have my old ADS200 and I want to be able to use both now and then.
The part number from Pace is 1213-0090-P5 (O-rings for TD-100, TD-100A, or TD-200, qty 5).You should also be able to find an equivalent based on its measurements. I think it is a Viton-type fluoropolymer rubber.
Sorry if this is already addressed but is the ADS200 Plus the same as what sellers such as TEquipment sell as simply the ADS200? Thankshttps://paceworldwide.com/news/introducing-ads200-plus#:~:text=Starting%20in%20the%20Spring%20of,be%20called%20the%20ADS200%20PLUS.https://www.tequipment.net/Pace/ADS200-8007-0579/Soldering-Stations/?v=0
