Author Topic: Pace ADS200 soldering station  (Read 514923 times)
Offline n3mmr
Re: Pace ADS200 soldering station
« Reply #1925 on: November 30, 2024, 05:24:35 pm »
So please share your experience with ADS200 Plus. I do appreciate if you even post a photo of the internal PCB.
Early days yet, I've not had the time to test irlt seriously.
It seems that the plus unit switches power on more often than the non-plus, but if that means it handles really heavy  loads better needs some thought on how to set the test up and how to quantify my findings.
If you'd care to specify some part of a test setup you're welcome!
As a first idea: I'm thinking a euro standard PCB 100*160 mm with 35 micrometer copper and try to create and later melt a solder island centrally placed.
Using a ¼" ultra chisel bit at 330°C.
Bring your ideas on.
Offline 2N3055
  • Country: hr
« Reply #1926 on: November 30, 2024, 06:40:51 pm »
Most interesting would be a photo of internal PCB, honestly. So we can compare if there was hardware redesign, or this is just different FW and redesigned tips..
Dr. Richard W. Hamming
Offline tooki
« Reply #1927 on: November 30, 2024, 06:54:34 pm »
Sorry if this is already addressed but is the ADS200 Plus the same as what sellers such as TEquipment sell as simply the ADS200?  Thanks
https://paceworldwide.com/news/introducing-ads200-plus#:~:text=Starting%20in%20the%20Spring%20of,be%20called%20the%20ADS200%20PLUS.
https://www.tequipment.net/Pace/ADS200-8007-0579/Soldering-Stations/?v=0
At my local supplier the plus unit is listed as plain ADS200. The part number is, I think, different.
Given Pace’s long history of retaining part numbers across revisions and even changes to the model number (!)*, I’d be very surprised if Pace updated the part numbers for the Plus versions.
*For example, the SX-80, SX-90, and SX-100 desoldering handpieces share the same part numbers: 6010-0106-P1 for the ones with black SensaTemp connectors, 6010-0149-P1 for the ones with blue IntelliHeat connectors. And the internal heater connector changed halfway through the SX-90 era, so when replacing an SX-90’s heater, one has to look out for that, too — one version is black, one blue, and that is independent of the black or blue external connector! So 6010-0106-P1 (black external connector) can be an SX-80 with black heater connector, SX-90 with black heater connector, SX-90 with blue heater connector, or SX-100 with blue heater connector, and 6010-0149-P1 (blue external connector) can be an SX-90 with black heater connector, SX-90 with blue heater connector, or SX-100 with blue heater connector. (The blue external connector was introduced after, or alongside, the SX-90, so there was never a blue-connector SX-80.)
« Last Edit: November 30, 2024, 06:56:57 pm by tooki »
Offline bdunham7
« Reply #1928 on: November 30, 2024, 06:58:44 pm »
The main question for me is whether they've increased the transformer secondary voltage.  My second question would be whether the new FW is compatible with the older non-plus systems.  IDK why they'd need to respin the board, but if they did then it's possible that the new FW won't work with the older boards.  That would be a shame since I think the biggest (and easiest)  improvement needed was to increase the effective duty cycle by reading the thermocouple less often when the tip temperature droops significantly.
Offline tooki
« Reply #1929 on: December 01, 2024, 10:36:40 am »
As I understood it, in the original ADS200, they never came close to running anywhere near 100% duty cycle, so even if you read the temperature 4 times a second you could still increase the duty cycle a lot, without needing to increase voltage or anything.
Offline bdunham7
« Reply #1930 on: December 01, 2024, 06:45:19 pm »
From what I saw on mine it reads the TC about 3 times per second but the read cycle involves a 70ms power interrupt so the power-off time is 210ms per second or about 20%.  The two things I can think of to improve this just in software are to decrease the frequency of the TC read cycles when the tip temp droops enough that it cannot recover in ~300ms anyway and perhaps to shorten the TC read cycle at a sacrifice of accuracy when the tip temp is low.  I'd think they could go from ~80% max on time to >95% just in firmware.  However, I think that only gets them about halfway to their advertised power rating at best.
https://www.eevblog.com/forum/reviews/newest-pace-ads200-production-station-(a-jbc-killer-at-$239)/msg4961779/#msg4961779
« Last Edit: December 02, 2024, 04:44:02 am by bdunham7 »
Offline rce_pirate
« Reply #1931 on: December 03, 2024, 05:00:31 am »
i just bought an ads200 from the website on nov 30th. SKU: 8007-0578 - i think that is the plus. if someone wants me to run some speicifc tests let me know. i have a jbc cd1-bqe as a comparison. its old but still works well. just trying to change my daily driver to a newer company. i dont like jbc's customer service, been a interesting experience with the b-iron line of products....
Offline Shock
« Reply #1932 on: December 03, 2024, 12:13:20 pm »
After you've had a play if it's not beyond your ability, a shot of the transformer and good pcb front and back photos would be of interest. As well as the firmware version.
Don't expect it to behave like the JBC, on certain JBC models the heating to setback/standby temp and overshoot are not display to the user. The original ADS 200 by design was more conservative heating the last 20C or so.
Many of the previous user comparisons of stations more compare the regulation accuracy and confuse a large mass with an insulated ground plane, making the tests about higher temps than power or throughput, so the outcome can be skewed.
The testing performed by actual manufacturers however tracked external tip temp and multiple conductive (uniform) targets so you could see actual tip recovery in action and the data made sense.
Perhaps a video of the display during a room temp bare tip (small chisel) heating up from power off. Then some soldering observing the display during some easy targets that go quickly molten. This may show any firmware changes around or near set temp.
Offline rce_pirate
« Reply #1933 on: December 04, 2024, 05:30:03 am »
i am sure i can do some of that, should be coming this weekend. i was actually interested in pulling the firmware myself just to understand that part. i am in the middle of doing a bunch of bga chip off's so this will be a piece of cake to test out soldering. i have some boards for testing.
The following users thanked this post: pope
Offline knotlogic
  • Country: sg
« Reply #1934 on: December 04, 2024, 01:26:52 pm »
Hi n3mmr, am I reading right that you have both the older ADS200 and the newer ADS200 Plus?  I'm curious if there are any discernible differences between the tip cartridges between the two stations.
Their product launch page says:
Through redevelopment of the entire thermal cycle, from power source to tip-heater cartridge, the ADS200 PLUS is now more responsive when higher thermal demand is required in the soldering process, as well as offering improved thermal recovery.
Which I take to mean that they've made changes to the tip cartridge.  At the same time, I would have thought that they're fully compatible with the older version as it wouldn't make sense to have a second near identical line of tips for the ADS200 Plus, when they have the ADS200 and MBT360.
Which leaves the question of how would us end users be able to tell which is which.
Offline n3mmr
« Reply #1935 on: December 04, 2024, 07:26:06 pm »
The tips are identical, as far as I know.
I think there are hw changes plus fw changes to handle those hw changes.
But I have no idea what the he changes are. Once I have dealt with some stuff I need to prioritize I will take pictures of the internals and/or test the thermal performance.
The following users thanked this post: thm_w, 2N3055, pope
Offline tooki
« Reply #1936 on: December 04, 2024, 11:34:17 pm »
Again, Pace doesn’t change SKUs/part numbers when they update products, so 8007-0578 could be ADS200 or ADS200 Plus (though that part number does mean the 120V version with standard stand). With that said, Pace introduced the Plus early this year, so there’s no chance you’ll get a non-Plus version.
Offline Shock
« Reply #1937 on: December 06, 2024, 02:42:53 pm »
Everyone loves a good mystery.
Offline n3mmr
« Reply #1938 on: December 06, 2024, 05:18:18 pm »
I REALLY do NOT agree with that!
Offline n3mmr
« Reply #1939 on: January 16, 2025, 12:16:52 pm »
Today I got a new PLCC prom with firmware 1.5 for my older station, the ADS200.
That actually gave a real and immediate improvement in performance.
With the new FW I had no problem to put a large solder blob on a large 35μm copper PCB.
With 1.2 the ADS200 struggled even with large Ultra tips.
Now it was easy to do.
Offline 2N3055
  • Country: hr
« Reply #1940 on: January 16, 2025, 01:19:22 pm »
Hello!
May I ask where did you get it from?
I have 1.4 (that was released quickly after ADS200 was released) and wonder if there would be any benefit to switch to 1.5
Thanks!
Best,
Siniša
Offline Shock
« Reply #1941 on: January 16, 2025, 02:52:42 pm »
N3mmr so ADS200 1.5 and ADS200 Plus 1.6 that suggests there could be at least a small hardware revision in the Plus model.
I recall the more recently made original ADS200 had new caps and mosfets but those were likely just part subs as the stations were still on 1.4 firmware.
Would be nice if you can find time for some PCB front/back and transformer pics of the new ADS200 Plus. The original ADS200 microcontroller (with 1.2 firmware or Rev C) is an Atmel 89C51 RB2-UM under the sticker.
« Last Edit: January 16, 2025, 03:13:27 pm by Shock »
Offline n3mmr
« Reply #1942 on: January 16, 2025, 04:23:38 pm »
Hello!
Thanks!
Best,
Siniša
I got it from the EU rep for Pace, Factronix GmbH in Germany.
I bought the station in 2019 from the EU rep at that time, Welectron, and that is probably why I was handled by a German firm. They probably had to accept handling support for existing customers when taking on the representative role.
Offline Hydrawerk
« Reply #1943 on: January 16, 2025, 11:05:28 pm »
My ADS200 was bought in 2022 and there is 1-5 firmware version shown on the LED display.
Offline Hydrawerk
« Reply #1944 on: February 22, 2025, 02:20:01 pm »
My workmate has a PACE ADS200PLUS. I tried soldering a large ground plane on a PCB. It still has a worse soldering performance than a JBC AM station with a T245 handle. I think that the difference is in the soldering tips used. JBC tips have a better thermal performance, because they are more expensive.
https://www.tequipment.net/Pace/1131-0010-P1/Tips/?v=0
Pace 1131-0010-P1 13/64 inch Chisel (5.15mm) $19.35
https://www.tequipment.net/JBC/C245069/Tips/
JBC C245069 Cartridge Chisel 5mm x 1.7mm HT $33.30
Offline tooki
« Reply #1945 on: February 22, 2025, 08:34:27 pm »
A high price doesn’t cause something to perform better.  :palm:
A better product might be able to command a higher price, or it might not. Many factors come into play when pricing things.
The cost to manufacture it is but a small percentage (likely under 20%) of the price it’s sold at. So even a significant difference in cost to manufacture doesn’t necessarily translate into a difference in price.
The following users thanked this post: thm_w, helius
Offline Shock
« Reply #1946 on: February 23, 2025, 11:16:37 pm »
Thou shouldst employ a thermocouple to measure the temperature of the soldering station under trial, and direct thy focus upon throughput and recovery tests, not upon regulation tests. Otherwise, thou shalt appear a fool.
Offline IXIS42
  • Country: ua
  • "Repair of industrial electronics"
« Reply #1947 on: February 24, 2025, 07:36:03 am »
Hello! I want to buy a Pace ADS200 soldering station, but given some of its design errors, I'm still hesitant. But I see that you upgraded it to ADS200 Plus. What changes have been made there?
Offline thm_w
  • Non-expert
« Reply #1948 on: February 24, 2025, 10:26:00 pm »
The clone tips are manufactured for <$3 each, most likely JBC is capable of making them for a few dollars. So as tooki says, cost isn't really the relevant factor here. As shown above, the Pace tip is basically the same design as a JBC 210.
The issues probably not the tip itself, unless it was some manufacturing flaw, its likely in the hardware and software used to read and drive it.
No one here knows what has changed yet, other than manufacturer saying "some component changes".
Offline Electro Fan
« Reply #1949 on: February 25, 2025, 10:45:19 pm »
I called Pace.  Person I spoke with said the Plus has a higher duty cycle.  He didn’t have a spec on what the previous duty cycle was or what the new duty cycle is on the Plus - just “higher”.  He said the Plus is intended to deliver more power but he wasn’t up for quoting any wattage specs.  He said he didn’t think it was likely for non-Plus units to be upgradeable to Plus.  Net, net:  higher duty cycle but not much specific.
