And your question is?
If you gave the make and model of the hot air tool you are using, the dimensions of the QFP and the distance to the nearest of the surrounding caps you'd probably get a more useful response.
Toombstoning isn't the end of the world - just measure the offending cap with a cap meter in case you damage it and need to replace it, desolder it and refit it correctly.
