Author Topic: OC Robotics snake arm robot teardown.  (Read 7510 times)
Online H.OTopic starter
« on: April 27, 2017, 08:34:45 pm »
Thought I'd show you guys something you might not see every day. It's not that much electronics but pretty cool none the less.
This is a very early "snake arm" robot designed and built by OC Robotics in the UK. It was used during a repair project at a nuclear plant in 2004 and has been in storage ever since, recently it was decided to be torn down and I took the opportunity to shoot some photos during the process. I appologize for the somewhat crappy phone photos but that's what I had at hand at the time.
Basically what it is, is a stack of flexible sections, 11 in this case, forming the "snake" - sort of like a human spine.
Three stainless steel cables are then anchored to the "end" of each of these 11 sections and threaded back thru each of the previous sections, thru a system of pulleys and back to a set of actuators. By pulling/releasing on the cables the "curvature" of the snake can be controlled:
The snake is positioned on top of pole which is attached to a vertical slide with which you can manually adjust the height, this was mostly done to get the overall height down for transportation and storage.
To be continued...
« Last Edit: April 27, 2017, 08:45:30 pm by H.O »
The following users thanked this post: SeanB, thm_w, nowlan, albert22, lem_ix, arvidb
Re: OC Robotics snake arm robot teardown.
« Reply #1 on: April 27, 2017, 08:36:25 pm »
Then the other end of all the cables, where they enter the base of the machine...
And distributed...
to one row of actutors:
Lifting the cover exposes all the actuators, each with its dedicated servo drive (more on that later):
To be continued...
« Last Edit: April 27, 2017, 08:46:29 pm by H.O »
The following users thanked this post: SeanB, albert22, arvidb
« Reply #2 on: April 27, 2017, 08:38:22 pm »
Each actuator is hinged to the base around the point where the cable enters the actuator. This allows the actutators to be folded out for access:
Here we can see the cables coming from the actual snake on the left hand side and routed into two rows of actuators. Note how the cable passes thru the shaft for the idler pulley:
These actutors are really quite clever. Just looking at them it took us a couple of minutes to figure out how they worked.
The motor (a MAXON RE40, 150W) drives a 14:1 wormgear, firmly attached to the output shaft of the wormgear are two belt pulleys. The 2100mm long endless AT5 belt is run thru the actuator and attached to the "shuttle" with a pulley arangement providing a further 2:1 reduction ratio. Following the belt path around inside the actuator it looked like the "shuttle" would just never move, it appeared as if the belt would just "circulate" inside the actuator without actually pulling the "shuttle" in either direction.
The clever part, and what allows the "shuttle" to actually move, is that one of the two driving belt pulleys on the wormgear output has one tooth more than the other. This makes one "side" of the belt drive "feed" 5mm more belt than the other side for each revolution which, due the 2:1 pulley ratio, moves the "shuttle" 2.5mm. All in all it takes the motor 28 revolutions to move the "shuttle" 5mm. I've seen a few belt driven linear actuators before but nothing quite like this.
Each actuator has it's own servo drive, also custom designed for the application. The supply for the drive is 48VDC and they are "attached" to the control system via a CAN bus.
To be continued...
« Last Edit: April 27, 2017, 08:47:24 pm by H.O »
The following users thanked this post: SeanB, albert22, lem_ix, arvidb
« Reply #3 on: April 27, 2017, 08:42:37 pm »
Nothing too exciting really. Power in top right corner, fuse, 39uF capacitor across supply. T2/T3 are the two low side switches in the H-bridge, 30mOhm current sense resistors on the low side of each leg. TLC274 for the current sense circuitry. LS7166-S 24bit quadrature counter handles the encoder.
Bottom side, 89C51CC01 with built in CAN controller, MCP2551 CAN tranceiver, 78L05 regulator, TL431 reference, the two top side switches of the bridge and the HIP4081A bridge drive IC.
On the system level there was a big box with a 1.1kW 48VDC switch mode power supply for the motors, a 24VDC auxillary supply, safety relay, contactors etc. A standard Windows XP PC for the userinterface which communicated with an "industrial PC" (a stack of PC104 stuff from Versalogic) via ethernet. The "industrial PC" then handled the CAN-bus and some discrete I/O signals. Unfortunately I don't know anything about how the software was divided between the system, which one handled all the calculations etc.
The robot was controlled using a bog standard gamepad controller. The aproach was (and still is as can be seen in the videos linked to further down) that you steered the "head" of the snake and the body followed wherever you went (within limits of course). The path was recorded so you could easily "retract" and/or play back the path.
As I said, this was some 13-14 years ago now but I'm happy to see that OC Robotics is very much still around (no I don't work for them). Here are a couple of vidoes I found that may give you a better idea of how it works and see some "in action":
The second one is a little bit of a MAXON motor infomercial but look and listen beyond that to see what the robots can do (I remember Andy, the guy in the video, from when we did the project for which the robots were bought):
If you look at 1.15-1.25 in the following video you'll see the very robot I just tore down. The footage is from a mockup but the still images are from the actual repair.
We have a second one exactly like this one and also another shorter but more rigid unit. The principle is exactly the same but the engineering that went into that one is even more impressive due to serious space constraints. If there's any interest I'll shoot some pictures of it too, haven't decided its faith yet.
Anyway, not much electronics but I hope you found it interesting none the less.
« Last Edit: April 27, 2017, 08:48:17 pm by H.O »
The following users thanked this post: lem_ix, arvidb
Offline Vgkid
« Reply #4 on: April 28, 2017, 01:38:36 am »
That is really neat, thanks for showing this.
I've seen enough hentai to know where this is going.
The following users thanked this post: arvidb
Offline thm_w
  • Non-expert
« Reply #5 on: April 28, 2017, 09:41:16 pm »
Very interesting, it looks like there is no grease or oil on the stainless cables at all.
So seems to operate similar to a bike cable in the upper areas of the arm, teflon or similar?
« Reply #6 on: April 29, 2017, 02:23:24 pm »
Looking at it it seems to be a combination of Vesconite hilube as the sleeves and phosphor bronze in the ends as guides, so it will be self lubricating and reasonably hard wearing. Vesonite is a lot harder than PTFE, and a little easier to machine, but is self lubricating to some degree and reasonably dimensionally stable. I have been using it as replacement material for a while now to replace brass and bronze bushings, as it works well in low speed low lubrication areas, and survives dust quite well.
« Reply #7 on: April 29, 2017, 03:27:16 pm »
Nope, no oil or grease on the stainless steel cables. From the base of the machine up to the actual snake they run in "flexible wire guide tubing", very much like a brake cable on a motorcycle etc. The dark grey discs on the snake itself feels like metal of some sort (hard anodized aluminium would be my guess) but I don't know for sure, I don't think it's not any sort of plactic as it feel to cold for that.
Hadn't heard of Vesconite before but it certainly matches the color and application, it might be it but again if Vesconite feels "plasticy", like PTFE or even PEEK does then it probably isn't.
I'll take a closer look at the remaining two machines on Monday.
Offline Bud
« Reply #8 on: May 02, 2017, 09:30:29 pm »
Holy smoke !  :-+
Offline xls
  • Country: sg
« Reply #9 on: August 08, 2022, 02:38:10 am »
Very interesting. Are there any other updates?
« Reply #10 on: August 09, 2022, 11:52:05 am »
From me, no.
The company I work for has changed ownership, is no longer in the nuclear repair business (nobody needs nuclear power, right...) and I no longer work at that particular department of it. I do know that they basically just threw it all in dumpster.
As far as photos goes you've seen what I have to show. I wish I had tore down and documented the other model we had as the engineering and machining that went into that one was even more impressive.
I "might" have saved a couple of RE40 150W servo motors from the dumpster - just saying :-)
Offline arvidb
« Reply #11 on: September 01, 2022, 08:00:59 am »
Glad you saved at least some of the motors! Seems like a horrible waste scrapping those beautiful things. :)
Thanks for taking the time documenting and posting. Very cool robots!
