I tried one of those, the suction is close to non-existent.
I agree with this statement, but I was able to improve the suction of a similar looking solder sucker that I bought many years ago.
When mine began to work poorly, I noticed that the o-ring on the plunger had shrunken. Since I needed to get the thing working again quickly I lifted off the o-ring using a dental pick and wrapped a single layer of 24 gauge buss wire in the area where the o-ring sat to enlarge the diameter of that area a bit.
Next, I filled that same area with plumber's silicone grease. I also coated the o-ring with the same grease and reinstalled it. The o-ring was now a slightly larger diameter and exhibited a tighter fit when I slid the plunger assembly back into the blue barrel. The suction was better after this simple tweak.
If anyone has a similar style of solder sucker, this may be worth a try if yours seems to have given up the ghost.
Regards,
Frank
PS, I also have a HAKKO 808 and it is a very nice device. It deserves all of the good reviews that I saw on Amazon.
"Plumber's grease"...
www.pexsupply.com/Hercules-40610-Plumbers-Silicone-Grease-2-oz
