Author Topic: anko micro HiFi system disassembly  (Read 75 times)
Offline jonovidTopic starter
    • JONOVID
« on: Yesterday at 11:53:10 pm »
Description as sold· Bluetooth connectivity · 30W RMS output power · AUX in · USB playback · Mains powered · LED display · CD player, FM radio, AUX input, USB playback.
found in the hard rubbish collection on the street. with the speaker wires cut. someone had tryed/ tested it with better speakers but then throw it out anyway.
my opinion
cheap mains powered FM radio for the shed , kids room or worksite.
with remote control with quality silicone keypads &  bluetooth connectivity plus front panel CD disc & USB playback.
IMO more LoFi then HiFi ! system has some bass at low volume. However poor single driver speaker design for the claimed 30 watts?
with thin speaker wires that are too short. color coded molex connectors at the rear panel.
However had RCA sockets audio output and a 3.5 mm socket for auxiliary audio input.
the permanently wired power cord has no plug-to-rear socket However has front panel on/off push button switch.
noise- all in one pcb design  see images.
some switch mode power supply noise bleed over some young ears can hear. see other reviews.
front panel design has No rotary encoder only UP/Down buttons. basic monochrome LED segment display.
poor FM sensitivity! even with the 1 meter wire in the rear panel TV type socket . no AM  disappointing
has FM auto tuning system.
folded sheet metal case with plastic front panel & black vinyl covered thin particle board speaker enclosures with plastic bezels & rear facing bass parts.
Hobbyist with a basic knowledge of electronics
