Author Topic: Pick and Place with vision.  (Read 21220 times)
Offline electrodacusTopic starter
    • electrodacus
« on: March 22, 2015, 03:15:00 am »
Has anyone seen this or have one. I seen first one today on aliexpress for $5800 and then found this youtube video.
I will realy love one for my Solar BMS project there are many small parts and the worse one is probably a 48pin 0.4mm QFN
Seems realy similar to TM240 and includes dual camera. Based on this video seems excellent.
Edit:
I went to the website mentioned in the above video and it seems is ?28800 = $4635 and that is fantastic price.
Here are some photo from that taobao website
« Last Edit: March 22, 2015, 03:55:04 am by electrodacus »
Offline pickle9000
Re: Pick and Place with vision.
« Reply #1 on: March 22, 2015, 03:32:12 am »
Have you seen this one? Vision is shown at the end.
??????????? ??????? SY-R46404VZ T15-F30-V4 SMT BGA ??
Offline rx8pilot
« Reply #2 on: March 22, 2015, 07:45:43 pm »
Looks like a logical and MUCH needed upgrade to that type of machine.
Offline pickle9000
« Reply #3 on: March 22, 2015, 08:01:35 pm »
This is an ad, I can't tell if these are manufactured by the same company or not.
http://translate.google.ca/translate?hl=en&sl=zh-CN&u=http://item.taobao.com/item.htm%3Fid%3D39350261877&prev=search
    • electrodacus
« Reply #4 on: April 05, 2015, 06:52:41 pm »
Still no news about this ? or a similar priced model with vision.
I can still wait a few months before I realy need one. I hope something will come up.
If not I will probably get one of the least expensive ones without vision and place the QFN and other smaller parts by hand.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #5 on: April 05, 2015, 07:16:58 pm »
On the 4-headed one, feeder layout looks rather poor - looks like feeders only on one side so numbers very limited.
Doesn't look like either has auto tool change.
Not obvious if either had a fiucial cam
Not sure I see much value in a small QVGA touchscreen display built in - too fiddly to do anything useful - much better to do it from a PC - maybe a web interface?
Surprised that nobody seems to have thought of using the system used on my 20 year-old versatronics- flying camera, flipping a mirror under the nozzle on it's way from feeder to board - significant placement speed increase with no extra mechanical speed needed.
« Last Edit: April 05, 2015, 07:24:34 pm by mikeselectricstuff »
Day Job: Mostly LEDs
    • electrodacus
« Reply #6 on: April 05, 2015, 08:18:35 pm »
Thanks Mike,
Not interested in the 4 head version well over my budget.  The small version has to heads and you can have a head configured for smaller components and one for larger ones.
The screen is not so important and I'm sure it does not add to cost much. But the fact that it can work independent from an external PC is a big plus for me. I have limited space and energy available.
It has dual cameras one on the bottom for checking component rotation and position and the other one mounted on the side of the head is probably used just for fiducial.
The mirror thing seem like an ingenious way to save time but not sure how it will work. If you flip a mirror under the nozzle the camera will be to far and will see things at an angle also flipping the mirror may not be much faster since this machine is extremely fast and probably the most time is spend for image recognition.
The nozzle is quite close to PCB so the mirror will need to be flipped out somewhere outside the PCB area not sure how exactly that versatronics- flying camera was designed.
Anyway even with bottom camera they can populate a few thousand parts per hour and that is more than sufficient I can not bake PCB's that fast anyway.
I can do a few hundred parts per hour manually so is 10x faster not to mention it will not get bored or tiered :)
Dacian.
Offline jc101
« Reply #7 on: April 06, 2015, 01:50:02 pm »
I tried all sorts of searching with regard to this, couldn't find a huge amount and what I did find was in Chinese which didn't translate.
One place I stumbled on mentioned they had some in the UK, so could be bought without suffering the import duties as it was shipped within the UK.  I thought I had bookmarked the page but didn't, may have another look at some point.  If I find it I might see if I could go and take a look at one...
« Reply #8 on: April 06, 2015, 02:03:32 pm »
There appear to be some operations that stock containerloads of popular Chinese ebay kit in the UK for direct shipping - I doubt they are the sort of place you could go look, or have the first clue about what they are selling.
What isn't clear on the 4-head one is what, if any, feeders are included.
    • electrodacus
« Reply #9 on: April 06, 2015, 04:50:55 pm »
Look this seems to be their Aliexpress store sor of eBay in China but page is in English. I used Aliexpress quite a few times.
http://www.aliexpress.com/store/product/2013-New-Tech-PCB-SMT-machine-pick-and-place-machine-Full-Automatic-Chip-Mounter-Upgraded-from/210206_1395653211.html
They sell a lot of other stuff see
http://www.aliexpress.com/store/all-wholesale-products/210206.html
They also sell the CHMT36 without vision that sells for quite some time and now this CHMT48V
It seems they sold two if this new ones and got one positive feedback.
Is about out of my price range and probably needs some shipping and import tax. I still have some months before I will need one maybe there will be something better for me. But from what I can see it looks to be realy nice.
Offline jc101
« Reply #10 on: April 06, 2015, 05:21:05 pm »
Thanks for this, I hadn't found that page.
One of the previous buyers shows as the UK too, which might be of use.
I will do some more reading and might see what other information they have available in english.
Just trying to keep abreast of what is out there, might get to a point later in the year where I need something and that is about the max in terms of physical size I could find a home for.
Offline alexanderbrevig
  • Country: no
  • Musician, developer and EE hobbyist
    • alexanderbrevig.com
« Reply #11 on: April 06, 2015, 06:09:20 pm »
wow!
Offline Kjelt
« Reply #12 on: April 06, 2015, 06:32:33 pm »
I find it too expensive as a hobby tool and it looks too crappy for a pro tool.
It all depends on the quality of the software and the longevity of the hardware, both should prove themselves.
If you are really making money with this and need to do >50 pcbs a week and depend on it  than a second hand pro machine as Mike has or now rx8pilot probably is a better investment.
Offline rx8pilot
« Reply #13 on: April 06, 2015, 06:54:17 pm »
Agreed. The middle ground is a strange place for Pick and Place that has not been addressed. $5k+ is a lot to put into a hobby for an assembly machine that also requires a slew of other pieces and parts to make it useful. A super low-end random manufacturer is scary for those that are banking a living on the machine to perform when it needs to.
I would be more than will to sacrifice speed for reliability to keep the price in check for low-volume. 1 head, up/down cameras, nozzle changer, flexible feeder system that can support big parts, etc. For cost savings, I like the head indexed feeder concept. The automated feeders on commercial machines are very expensive to get the extra performance. Head indexing is slow, but who cares when you are only doing 150 PCB's per week.
If I was going into the $5-7k PnP business, I would focus on the needs of small businesses that will spend that in a flash if it is not a toy. For me and many other businesses - speed is not the goal. Ease of use, ease of project changeover, and reliability are what is important to me. Not sure what I could accomplish in that price range, but then again I will not likely enter the PnP market ever.
    • electrodacus
« Reply #14 on: April 06, 2015, 07:02:22 pm »
I have limited space in my home also limited energy (OffGrid) I find that old machines are not a good solution for me. They are large shipping may be extremal expressive then it may need expensive parts hard to find and uses antique software tools and external computer to run.
This are plug and play machines all includes much smaller and extremely fast. The only problem is that at the current volume I can almost do thing manual. But If I try to outsource the assembly I may need to pay same or more as I do for this machine just for 100 units of my new solar BMS plus the risk of fake or inadequate parts and improper soldering.
I will probably end up with the TM220A is quite a bit less and I will do the critical parts few QFN manually.
Longevity should be no problem for such low volume and I can probably easy sell that after I'm done with the job for not much loss. I will probably keep it for future projects.
I realy like this machines they are extremely fast and work in-depended from an external computer they just need a csv file for placement.
Pick and place SMT parts is not a job for humans :) I done that on the fist Solar BMS and that was no joke plus that had only half the parts this new one has.
Offline rx8pilot
« Reply #15 on: April 06, 2015, 07:43:35 pm »
Your strategy is reasonable. I nearly went that direction myself. Some luck went my way and I found a used Quad machine that should be able to out class my needs for the foreseeable future. It is, as you point out, heavy, big, and nearly 2x the cost after it's all said and done. The good news is that it is about 10x more capable but it sounds like that capability would be lost in your situation. At least for now. Hopefully your project will get some traction.
I had considered using TM-240a to place the easy parts and hand place the hard stuff under a microscope like I do now. It would still be an improvement from full manual for sure. Making the transition to production is quite tricky as I have found - balancing time and money.
Offline Kjelt
« Reply #16 on: April 06, 2015, 08:59:28 pm »
I understand the size problem and maintenance costs are a big issue for non pro start ups.
The problem as rx8pilot also states is that there is not much out there for that class. If you want to buy a brand new car you can,t find anything below 10k at least here in europe and there is a good reason for that.
If some company starts to sell cars for 3k brand new I would be very suspicioys.
The same here , the brand name alone sound all alarmbells. But if there as  you say are already machines out there I would contact that buyer and ask for their experiences and uses.
That can,t be right can it? $50 per pcb just for the assembly? Rediculous. I would ask around for other businesses then the startup costs are high i know that.  you can ask how you can lower them for instance make sure the files are compliant with their process.
Offline pickle9000
« Reply #17 on: April 06, 2015, 09:25:58 pm »
Extreme low quantity and one off's can be a killer. A low cost machine (sub 2000.00 usd) even without vision would make a killing.
Offline rx8pilot
« Reply #18 on: April 06, 2015, 09:59:12 pm »
In small qty's that is about right. I got a quote from multiple sources for small batch PCB's in that ball park. The documentation, kitting, setup, programming, testing, shipping divided by a small qty is expensive. That is why I now have a PnP machine. My first 100 sets of PCB's will nearly cover the purchase price. The cost drops very fast as volume goes up - dividing the NRE into smaller parts.
« Reply #19 on: April 06, 2015, 10:07:48 pm »
The problem is that so far,  the cheap machines have been dead-ends.
What's needed is something that has a low entry cost, but can be expanded over time -feeders, vision, multiple heads etc.
Anything without vision is a toy,  as hardware cost is so low there is little excuse these days for not having it.
Offline rx8pilot
« Reply #20 on: April 06, 2015, 10:12:33 pm »
Even the software components are open source.
Offline pickle9000
« Reply #21 on: April 06, 2015, 10:22:53 pm »
A modular system would be ideal. I'd still say a basic system (even without vision) but with good placement resolution and cheap feeders is a reasonable place to start.
    • electrodacus
« Reply #22 on: April 06, 2015, 11:05:08 pm »
Yes low volume assembly is quite expensive especially when you have a relatively complex design with many parts and also include 0.4mm pitch QFN.
Also each Solar BMS has two PCB's the main one is more complex but there are quite a few parts on the power board (is a metal core PCB).
So yes at least 50 to 70$ to have them assembled and then there is also the risk of soldering quality issues or non genuine parts used.
As for available pick and place there is that guy here on the forum with a $1500 unit with vision but extremely slow based on CNC hardware about 300 parts per hour and that is worse than manual so useless. Then there is the $4000 + shipping for the TM220A or $5000 for the larger TM240A Next is the CHMT36 a clone of TM240A for the price of TM220A and this newer CHMT48V that is even larger (not so important for me) and has vision based on youtube video the best implementation of vision I seen cost 5800 + shipping.
All this P&P have 4000cph with vision to 7000cph without both faster than I relay need.
What is missing is something in the middle $3000 decent speed at least 1000 components placements per hour with vision.
Maybe something will pop up in the next few months before I finalise design and start production.
This CHMT48V is great if it was $3000 I will have invested right now.
Offline smgvbest
    • Kilbourne Astronomics
« Reply #23 on: May 11, 2015, 04:40:34 pm »
Has anyone looked at this one.
https://youtu.be/CRSLbo_8nTQ?autoplay=1
opensource, DYI Pick and Place with vision and paste dispensing
Has 1 place head and 1 paste dispensor.
Full site here
https://www.vbesmens.de/en/pick-and-place.html
I've thought about building it myself
Sandra
(Yes, I am a Woman :p )
Offline rx8pilot
« Reply #24 on: May 11, 2015, 04:58:47 pm »
There is no one on earth that can consistently place 300cph for any time at all. You can 'maybe' do a burst of the same component repeated in an easy to memorize geometric pattern. If your board has any complexity at all with a significant component count - you will very much benefit from a 300cph machine. People need breaks, get distracted, place a 1k where the 10k goes, etc.
While you are inspecting, printing another PCB, loading software - the machine would be putting down components. It is FAR from useless. This is coming from someone that has placed nearly 100,000 components manually in the past year. I have all the tricks and TONS of practice. I have great eyesight, tools, and coordination. I have also engineered an organization system for the components and reference materials to speed things up.
I am not saying 300cph is fast - I am saying that it is MUCH faster than what a human can do for any useful length of time.
