Author Topic: Question to Eakins Microscope owners 13MP SONY IMX307  (Read 418 times)
Offline tonycstech
« on: October 07, 2022, 04:25:57 am »
Hi guys, i recently bought   Eakins Microscope 13MP SONY IMX307 and i immediately ran into few problems.
#1 Seller: Eakins Microscope Store. Does not respond.
#2 What i see in the HDMI output is much more narrow then what i see through the eyes.
Is there a way to match what i see vs whats coming from HDMI output ?
Like some kind of an adapter maybe ?
#3 at the bottom of the screen (hdmi video) is a black line just few pixels tall. Annoying but its there. Is it the sensor problem ?
#4 It seems like the camera has to be twisted way out of parallel in order to produce parallel image. Sensor inside the camera not mounted properly ?
#5 i need  a beam support. Whats it called ? Maybe a link ?
The table it came with does not support the scope weight.
The following users thanked this post: crgarcia
Offline crgarcia
  • Country: ar
Re: Question to Eakins Microscope owners 13MP SONY IMX307
« Reply #1 on: October 11, 2022, 07:33:50 pm »
I don't have one, but I was about to buy it (now I am not sure if I should)
Anyways, for #2, there are some adaptors. Here there is a video that shows them (sorry, it's in spanish, hope the auto-subtitles work): https://youtu.be/JZIXropgrB0?t=346
Let us know if you could solve them!
« Last Edit: October 11, 2022, 07:36:34 pm by crgarcia »
Offline PlainName
« Reply #2 on: October 12, 2022, 08:15:52 pm »
The "0.5x mount adapter" in the image - the one with the fat middle and thin ends - is what you use to do that. It sits between the camera and microscope. It still won't be perfect, though, since the HDMI is likely widescreen and your eyes are square(ish) format, so there will be top and bottom crop to some extent.
previously known as dunkemhigh
