I have several of those, I use them to charge 24 Volt gel cells from 12 volts in a car, work fine for me I also have one that goes to 90 Volts that I intend to use in an old valve radio that runs on batteries 90 volt batteries are no longer available and as there is room inside for a big glass lead acid 2.5 volt for heaters I intend to put a small 12 volt in and bost for HT and have a buck for LT.
