Author Topic: Recommendation for SMD hot plate?  (Read 4653 times)
Offline BreakingOhmsLawTopic starter
  • Certified solder fume addict
« on: March 15, 2021, 06:22:15 pm »
Hi everybody,
What's the current go-to part for a decent hot plate?
My requirements are mostly quick part recovery from prototype boards, 100x100mm size would be fine.
Are any of the Chinese made plate you find on banggood any good, or are they deathtraps?
I've seen the recent 30x30 "mini" hot plate Dave tested, but that is definitely too small. I basically want to whack the board on the plate, wait for it to heat and recover the expensive ICs before trashing the board. No reflowing or other funny stuff intended.
EDIT: I bought a HT-2008, teardown and review here:
https://www.eevblog.com/forum/reviews/ht-2008-90-smd-hot-plate-death-trap-teardown-review/new/#new
« Last Edit: March 20, 2021, 05:00:55 pm by BreakingOhmsLaw »
Offline jpanhalt
Re: Recommendation for SMD hot plate?
« Reply #1 on: March 15, 2021, 08:04:35 pm »
For mass harvesting of SMD IC's, I put the board over a trash can (adding crushed paper, sawdust, or straw is optional), heat the back with a propane torch, and occasionally tap it as a small nudge.
« Reply #2 on: March 16, 2021, 12:23:42 pm »
Working with an open flame in my office is a sure-fire way of getting myself fired  ::)
And it's not mass harvesting that I need, I just want to pick that €40 Opamp from the PCB before sending it to the dumpster or preheat the PCB when i need to populate parts that weren't available at the board house.
I have two units on my shortlist:
QUICK 853
X1520T
Does anyone own these and can tell anything about them?
Offline tooki
« Reply #3 on: March 18, 2021, 04:19:14 pm »
For what it’s worth, at work we just got this one: https://www.reichelt.com/ch/de/infra-red-rework-heating-plate-800-w-station-ir-610-p105798.html
It just came yesterday, so I’ve only been able to test it the tiniest bit, but it seems to work well. It certainly has more than enough power to melt the solder and remove ICs. (I did that with a scrap board.)
Offline coppercone2
« Reply #4 on: March 20, 2021, 04:55:24 am »
careful with buying them on ebay, they have a specification for surface heat evenness, at least the good ones, used units that are cleaned up and look good might not have this specified uniformity. They will tell you something along the lines of "the specified surface heat differential minimum and maximums are at most some value of C when a thermal camera is placed x-inches from the surface"
So if you really want good SMD joints, I think its a big reason why people use IR heating, because you can tell the source is uniform.
The way to check it is using a thermal camera, so if you do not have one, using it for things other then heating beakers is not a good idea for what you are interested in. I got one once, thought it was nice, it cleaned up good, looked great, but the surface was un-even so it I don't think it was suitable for doing something like a thin heat sensitive PCB. The replacement top for it cost like 5x the price of the hot plate.
This is one of the parameters you are paying for, how long it stays uniform on the surface to specification.
« Last Edit: March 20, 2021, 04:59:00 am by coppercone2 »
Offline daniel444
« Reply #5 on: April 02, 2021, 12:02:59 pm »
crazy idea here but i just made one of these from a replacement stovetop electric element  1.8kw
you could make one similar and also buy a  1 or 2mm quartz glass window for it
the element is 170mm diameter
i run mine off a seperate dimmer box with 10ma rcd
i dont have a quartz window or intend to do smd soldering myself
the the quarts glass should have the best transmission of the infra red but it will be the most expensive part
« Last Edit: April 02, 2021, 12:04:56 pm by daniel444 »
The following users thanked this post: SilverSolder, tooki
Offline kripton2035
« Reply #6 on: April 02, 2021, 12:14:09 pm »
I bought this one and I'm very happy with it (except for the €30+ VAT I had to pay when it arrived...)
https://www.aliexpress.com/item/32692018362.html
Online TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #7 on: April 02, 2021, 12:25:32 pm »
I have this one which works well (My brother and I both have one each, and my brother uses his for small production work similar to your use case and it seems to work well).
I have since replaced the controller with a 'more genuine' one as the one supplied didn't have any real PID controls etc. It's pot luck what you'll get in regards to that so suck it and see, then make a decision if you want to replace it or not.
Offline SilverSolder
« Reply #8 on: April 02, 2021, 01:33:15 pm »
You can let out your inner neanderthal with a hot air gun too - it is surprisingly easy to control the temperature "just right" and get the parts off without damaging anything...   all you need is a bucket to catch the parts in - I use a plastic box with a damp rag in the bottom...
Online SiliconWizard
« Reply #9 on: April 04, 2021, 08:32:43 pm »
I've had a look at hot plates lately.
If you're thinking of buying something cheap off Aliexpress or the like, beware. I've done some searching, seen a few teardowns, and so on. IMHO, many of them have safety issues. The cheap ones are often based on hot plate elements that are aluminum and the heating element , just under the plate, is mains-powered (through some controller usually.) Those hot plate elements can be bought separately, so you can decide for yourself. Heck, they are a few dollars each, so with an additional DIY controller (a few bucks more) you can have a working hot plate. BUT I wouldn't trust them for safety reasons. Isolation between the hot plate and the heating element is often pretty poor.
Offline blacksheeplogic
« Reply #10 on: April 09, 2021, 09:11:49 pm »
I have a Weller WHP3000 + Board Holder, and a Weller WHP1000. I would recommend either of these but not for casual occasional use.
« Reply #11 on: April 13, 2021, 12:54:52 pm »
You are absolutely right. I ended up buying a Chinese one, and have fixed some serious safety issues. The hot plate itself was grounded though, but the metal case wasn't. Also no fusing whatsoever to be found.
See:
The following users thanked this post: SilverSolder, SiliconWizard
