Had to dremel out the battery compartment of my glucometer today. The two coin cells that came with the unit were over 15 years old. Bought two new ones from Jaycar. Didn't fit. The newer battery has a deeper positive terminal and plastic lip around the battery's negative terminal in the holder prevents the batteries from being inserted fully and therefore the battery door wont clip in.
I got by, it's now working fine. My question is do these batteries change physical specs often? I mean, the two sizes, width and thickness which define the battery are correct. Is it the device manufacturer's fault for putting that silly, redundant lip of plastic underneath the positive terminal.
