Recently I got this unit.
I was looking for a small and compact and, of course, cheap hot air station.
I was really unsure to get this one instead of the other and more cheap 858D on ebay. I was interested on the youyue 858D due the possibility of hacking, the better quality of the board, and the possibility to remove the hand piece.
What I don't like on the youyue is the bad front DIN connector with an exposed pin connected directly to the main plug.
So I decided to get the Pro'sKit instead, it is more expensive but the overall quality looks better and it has no deadly issue ... or so I thought.
This is what I got:
The unit is changed, there are some cosmetic changes, red buttons, a different knob, but most important there is the wrong and dangerous DIN connector like the youyue!
And yes, like the youyue there is a pin directly connected to the main plug:
Of course in this way you can accidentally get the 220V. Even when the unit is off!
And this is the inside:
There is no brand on the main board, but it is very similar to the youyue board.
And the main IC is an ATMEGA8 like in the youyue.
This is the inside of the heat gun:
The little board with some awful solders.
This two wire are really close together.
So, this new Pro'sKit SS-969 is just an overpriced youyue. At this point there are no reasons to get this one in place of an "original" youyue or one of the other cheap unit on ebay.
