HI there,
I am new, sorry if I have not posted in the correct forum.
I am looking for a standard rf remote with 220V AC supply, but I can not find it. All the rf remotes (emitters) work with 12V batteries. I have even found ones that worked without battery but with a dynamo. But not one that works with 220v supply. All rf remote are like the one you would use to open a garage door.
The reason I need this is:
- I do not want to depend on a battery to run out and the whole setup stop working.
- I do not want to replace switches in my house, I want the installation seamless.
I tried to wire a 12V psu to one rf remote. I was afraid I could burn it and in fact it burnt.
I partilly solved the part of using same switch in the wall I was using in house with a 220V relay that closes the circuit of push button in rf remote. But I could not get rid of the battery.
So I have 2 questions for the guys here:
- Is there any rf remote that could be feed by psu or by 200V AC?
- Is there any way I could attach 12V DC to a rf remote without damage it?
THanks and regards,
chemanork
