Author Topic: which scope is wothy?  (Read 4221 times)
Offline aruna1Topic starter
« on: May 25, 2011, 04:17:58 pm »
see following two scopes
Rigol DS1052E
http://www.dealexcel.com/rigol-ds1052e-50mhz-band-widths-2channel-digital-oscilloscope_p363.html
UNI-T utd2052ECL
http://www.dealexcel.com/unitrend-utd2052cel-digital-storage-oscilloscope-bright-full-colour-lcd-2-channels_p3711.html
from what I see UNI-T has large display but low memory depth comparing to rigol but its cheap
shipping is $15 for both
what is your opinion?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: which scope is wothy?
« Reply #1 on: May 25, 2011, 06:01:13 pm »
Rigol DS1052E
Offline tekfan
  • Country: si
« Reply #2 on: May 25, 2011, 08:34:07 pm »
Yep. Rigol wins hands down.
One can never have enough oscilloscopes.
Offline Tony R
« Reply #3 on: May 26, 2011, 01:16:46 am »
Does anyone else find it funny that his name is tekfan and he is endorsing Rigol.
However I agree, having the choose between either of the two, the winner would be Rigol.
Tony R.
Computer Engineering Student
Focus: Embedded Assembly Programming, Realtime Systems,  IEEE Student Member
« Reply #4 on: May 26, 2011, 02:22:16 am »
thank you
Offline vk6zgo
« Reply #5 on: May 26, 2011, 02:27:27 am »
 I don't even like DSOs but I would also say Rigol.
If you ever have cause to look for low frequency noise,like hum,on a high frequency signal,you will appreciate
larger memory depth.
DSOs without much memory depth lower their sampling rates as time/div is increased,with resultant aliasing
problems.
A classic,standard test at TV stations was to look for hum,clamping error,etc on an analog video signal.
Even the early (1990s) DSOs from such illustrious firms as HP & Tektronix failed this test.
I don't have a Rigol,but from what I've read on this forum,it would pass.
If all you will ever do is look at signals at or around their period,maybe the UN-T would de adequate,but you may
find your requirements change.
Or, you could buy a secondhand Tektronix analog Oscilloscope,unless you really need all the DSOs "bells & whistles".
VK6ZGO
« Reply #6 on: May 26, 2011, 07:50:11 am »
I dont like to buy a secondhand one coz they are used and has more chance of breaking down  :-\
Offline RCMR
« Reply #7 on: May 26, 2011, 08:20:43 pm »
Actually, most electronic devices are more likely to fail in the first few hours of operation than for some considerable time after that.
Offline tekfan
  • Country: si
« Reply #8 on: May 27, 2011, 02:54:31 pm »
As long as it's properly engineered I don't care what brand it is.
The second thing is that memory depth is really useful, not only bandwidth and sample rate.
