Hi ,
Some days back i chanced upon a post by some people -> https://www.eevblog.com/forum/buysellwanted/gossen-metrahit-25s/ (https://www.eevblog.com/forum/buysellwanted/gossen-metrahit-25s/) . Rishabh is one of the top few companies making " Made In India " multimeters .Be it technology transfer or be it anything you can imagine .In my country we do have a few more companies making good multimeters .As a initiative i would like to involve you all in the discussion to give a thumbs up or criticise this multimeter .My focus is on DMM's And Clamp meters they manufacture in india along with the accessories .Once if i feel we have some positive vibe on this subject i will sell these multimeters worldwide with your support and understanding i am hopeful we would be able to do something for my country "everyone loves his country just i love india " .So here You Go with the first one today i will keep adding the stuff and discussing the same with you .We have a local distributor who can sell me the products and i can ship them if people want to buy the same .I will also try and arrange samples to send to dave if i can do the same .I will try my best
Rishabh Rish Multi 20 5 3/4 TRMS & Backlight Multimeter
(http://i46.tinypic.com/2lk4qbr.jpg)
Full Sized Image - > http://i46.tinypic.com/2lk4qbr.jpg (http://i46.tinypic.com/2lk4qbr.jpg)
Convenient Triple Display
Simultaneous measurement of voltage and frequency or voltage and min, max values is possible. Also current and frequency or the current measurement and minimum and maximum values are displayed simultaneously The usual switching back and forth between display values is no longer necessary. Main display resolution for AC is 4 ¾ places and for DC it is 5 ¾ places
High Resolution & Precision
5 ¾ places (309,999digits) for DC measured quantities and 4 ¾ places (30,999 digits) for AC measured quantities allow for precision reference measurements and use as a calibration standard for testing devices and assemblies.
RMS Value with Distorted Waveshape
The utilized measuring method allows for waveshape independent RMS measurement (TRMS AC).
Additional Functions
Resistance (Ohm), Temperature (°C), Continuity, Diode, Capacitance, Frequency, Duty cycle
Overload Protection
The instrument is safeguarded for up to 1000 V in all measuring functions by overload protection. An acoustic signal is generated if the upper voltage or current range limit is exceeded. FUSE appears at the display if the fuse for the current is blown.
Measuring Category
1000V CAT III/600V CAT IV as per IEC Standard 61010-1.
Automatic Blocking Sockets (ABS)
Automatic blocking sockets prevent incorrect connection of measurement cables and inadvertent selection of the wrong measured quantity. This significantly reduces danger to the user, the instrument and the system under test and in many cases eliminates it entirely.
Backlit Display
The instrument is provided with user selectable Back-lit for taking measurements in poor lighting conditions / dark areas.
Kindly Download Details Specification Datasheet - > Click Here (http://www.lynxchandigarh.com/scripts/fmanager/index.php?dir=Electronic%20Instruments/Test%20And%20Measurement/Rishabh%20Datasheets/&file=Rishabh%20-%20Digital%20Multimeter%20Rish%20Multi%2020%20Datasheet.pdf)
Pricing @ USD 305/- + Tax 12.5% + Shipping Approx [ 5 To 10 USD Worldwide ]
" Incase We Sell These ,Currently We Are Not Selling This "
Well I Expect My Post To Be Taken Positively As My Basic Intention Is To Showcase That In India We Do Have Some Decent Enough DMM's For Sale .I Will Also Try And List The Other Brands I Am Talking About Slowly .Lets Do This One By One .I Will Also List The Other DMM's They Have For Sale Here Those Are Very Decently Priced .If You Think These Can Be sold I Will Try And Source Them And Sell Them To you Folks .
The fact that the display is not a real picture but a doctored image is concerning. Show us a picture of the real display that is not a photoshop image. The shape of the segments on the numeral 4 are not the same shape as the other segments. Same thing on the data sheet images with other numerals.
Sir ,
I have no need to doctor anything .This image is taken out from the datasheet by me and posted .Here is Another Image ,Kindly Read My Line Under Pricing " Currently i Am Not Selling This " .But My Local Distributor Can Arrange This And Sell " .
(http://i46.tinypic.com/rsr3o6.jpg)
@ All : The Lower Models Are Also There With Extremely Decent Pricing .Gimme Some Time And i Will Post Atleast 1 Model Here everyday With everything i have access too .
Hello ,
Adding Their starting range of rugged multimeters The Rish Multi 11 .No Terminals Cover change in this model .
The Photo of the Unit
(http://i50.tinypic.com/9t1s1z.jpg)
MIN/MAX Value Storage : In addition to the display of the actual measured value, the minimum or maximum value can constantly be updated and stored. Indication of negative values on the analog scale : When measuring DC quantities, also negative values are shown on the analog scale so that variations of the measured value can be observed at the zero point. Automatic Data Hold : The DATA HOLD function makes it possible to hold the digitally displayed measured value. It is ensured that no freak value but the actual measured value is held in the case of rapid changes in measured quantities. The held measured value appears on the digital display. The actual measured value continues to be shown on the analog scale. Autoranging / Manual Range Selection : The measured values are selected with rotary switch. The measuring range is automatically matched to the measured value. The measuring range can also be selected manually via the AUTO/MAN push button. Continuity Test : This permits testing for short circuit and open circuit. In addition to the display, a facility of sound signal is available. Temperature measurement : It is possible to use RISH multi 11 in direct connection of temperature sensor Pt 100 / Pt 1000. The meter automatically detects the type of sensors connected to it & displays directly measured temperature. Overload Warning : A sound signal indication violation of the overload limits. Power Economizing Circuit : The meter is switched OFF automatically when the measured value remains unchanged for about 30 minutes and no operating control was operated during this time. The disconnection facility can be disabled. Protective Holster for rough duty : A holster of soft rubber with tilt stand protects the meter against damage in the case of shock and drop. The rubber material makes for the meter to stand firmly even on vibrating surface.
Download The Datasheet - > Click Here For The Same (http://www.lynxchandigarh.com/scripts/fmanager/index.php?dir=Electronic%20Instruments/Test%20And%20Measurement/Rishabh%20Datasheets/&file=Rishabh%20-%20Digital%20Multimeter%20Rish%20Max%2011%20Datasheet.pdf)
Pricing @ USD 56/- + Tax 12.5% + Shipping @ Actuals
PS : I Think I Would Be Able To lay my hands on this one in the coming week get ready for a teardown .
